WR1 Up pipe
WR1 Up pipe
Postby heffs976 » Fri Aug 21, 2015 5:06 pm
Hi guys could anyone tell me if the standard up pipe on the WR1 has got the temperature sensor in it?
I need a new up pipe and have seen several different ones, I remember on my last subaru wrx it had a up pipe with both the cat and the temperature sensor.
Am I right in thinking the WR1 has no CAT and it has the temperature sensor in?
Also any part numbers or links to new or decent second hand ones would be appreciated
Thanks
Neil
heffs976
Re: WR1 Up pipe
Postby asperformance » Tue Aug 25, 2015 3:12 pm
only the 2.0 WRX 01-05 cars had the "pre-catted" up-pipe with temp sensor - everything else just uses a std spec up-pipe
we do the custom Harvey Smith "trick" up-pipes
viewtopic.php?f=40&t=14740&p=196067#p196067
