Which clutch to fit?
Postby weirdfish » Sat May 24, 2014 9:58 am
As per title, which clutch do you guys favour.
weirdfish
Re: Which clutch to fit?
Postby W1 KRB » Sat May 24, 2014 10:35 am
I've got the exedy pink in mine, feels fine to drive everyday use, I'd prob recommend speaking to as performance on his thoughts but will most prob be the same
W1 KRB
Postby asperformance » Sat Jun 07, 2014 7:38 am
as above a "pink box" exedy clutch would do that job just perfectly although if its simply a road car then you would most likely get away with a std OE unit also
Postby weirdfish » Mon Jun 09, 2014 12:20 pm
Thanx for info, need to decide whether to go exedy or OE, how much will the standard clutch handle, and will it be ok with the lightweight flywheel that's been fitted to the car.
weirdfish
