Gearbox oil
Gearbox oil
Postby swiss tone » Sun May 04, 2014 10:36 am
I am just doing some fluid changes.
Anyone used the millers GL5 75w90 in the gearbox/front diff? Auto data says to use that but just want to know if that's correct really. Bit of a sod apparently filling back up through the dipstick I'm told, special tool avbl might be worth getting.
I have Motul 90PA for the rear diff as some posts suggest and 5w30 synthetic for engine oils with a subaru black oil filter.
swiss tone
Re: Gearbox oil
Postby Gary75 » Sun May 04, 2014 4:51 pm
swiss tone wrote:I am just doing some fluid changes.
GL5 75/90 for front gearbox / diff, use a length of hose cut to size or long funnel to fill, no special tool required :thumb: Motul 90pa rear diff,spot on. I'm back using 5w40 Fuchs Titan with blue filter.
Re: Gearbox oil
Postby swiss tone » Wed May 07, 2014 4:51 pm
Cheers Gary, garage doing it on fri :)
Good tip on filling gearbox though!
swiss tone
Re: Gearbox oil
Postby swiss tone » Wed May 07, 2014 4:52 pm
swiss tone
Re: Gearbox oil
Postby swiss tone » Mon May 12, 2014 5:55 pm
All oils done :D
swiss tone
Re: Gearbox oil
Postby swiss tone » Fri May 30, 2014 5:14 pm
I am bewildered as sick of hearing conflicting advice! Just had my one mot'd. Guy claims to be a bit of and expert with LSD diff's.
Passed with no advisories as expected after the amount of money I constantly throw at it but he said, what oils have I got in gearbox/diff and rear diff?
I told him only just changed the oils and millers GL5 75/90 in gearbox and Motul 90PA LSD oil in diff as most on here also suggest.
He said , god no, way too thick!!!! With car wheels off the ground, he turned wheels independently and said they were too stiff and thinner oil sorts it on these. He said what Subaru recommend is wrong!!!
Is he talking utter crap?? Anyone else run with thinner oil? :wtf:
swiss tone
Re: Gearbox oil
Postby Gary75 » Sat May 31, 2014 8:58 pm
swiss tone wrote:I am bewildered as sick of hearing conflicting advice! Just had my one mot'd. Guy claims to be a bit of and expert with LSD diff's.
I told him only just changed the oils and millers GL5 75/90 in gearbox and Motul 90PA LSD oil in diff as most on here also suggest. :thumb:
You have the right oils in the right places...
Is this guy for real... :cuckoo: you will have resistance from all wheels, they are connected to hubs, drive shafts / prop shafts...diffs and a gearbox.
So your guy claims he is somewhat of an expert on LSD diffs and Subaru's recommendations are wrong? What oil would he use or recommend in the gearbox and rear diff :?:
Re: Gearbox oil
Postby swiss tone » Mon Jun 02, 2014 7:57 am
I didn't warm to the guy. He said he will find out so I'm going to call in just to see what he says for the laugh element as it's only at the end of my road.
I'm with you on this one and too many people claiming to be so called experts. They do more harm than good as people actually listen to them and end up causing more problems. They should go back to greasing Fiesta's! lol :wink:
swiss tone
Re: Gearbox oil
Postby asperformance » Sat Jun 07, 2014 7:43 am
90PA is perfectly fine in the rear diff of an STi although probably a little over kill for a road car...........would more normally use 75w90 or 80w90 LSDS specific offerings from Millers / Motul
as for the engine i wouldn't personally use a 5-30w and would suggest a 5w40 min
