Engine warning Light
Postby HMR81 » Mon Mar 17, 2014 8:31 am
Driving home last night, slow speed and low revs my engine warning light came on and hasn't gone off. Any ideas what i can do, or is it a case of getting it to scooby to find out whats gone wrong?
#30 / 500
HMR81
Re: Engine warning Light
Postby Hammerhead » Mon Mar 17, 2014 9:14 am
Maybe call Autotechnica I am sure they will help
Hammerhead
Postby WR1 » Mon Mar 17, 2014 12:09 pm
I'd get an OBD2 reader and confirm the code (pretty cheap on the web) - use he 'Google' force which will probably give you an indication of issue. I my experience it's typically a failed sensor and not engine failure. But thats based from prior cars not my WR1. You can get the ODB2 readers which are wirless with an iPhone Ap which is pretty handy. Hope you fix it.
WR1
Postby Megaman » Mon Mar 17, 2014 6:56 pm
You need to get the codes read to find out what the issue is. It could be lambda sensor readings, or dodgy supermarket fuel or an issue with a missfire developing etc.
If it still seems to drive okay probably gasses related.
Postby HMR81 » Fri Mar 21, 2014 12:39 pm
i do have a pin hole in the down pipe so it might be detecting that i guess.
#30 / 500
HMR81
Postby scoops » Fri Mar 21, 2014 11:25 pm
HMR81 wrote:Driving home last night, slow speed and low revs my engine warning light came on and hasn't gone off. Any ideas what i can do, or is it a case of getting it to scooby to find out whats gone wrong?
I have a fault code tester... and I'm in warrington
scoops
