error code
error code
Postby ian1965 » Fri Dec 13, 2013 4:11 pm
My subaru has come up with an error on my local garages diagnostic equipment, brake boost pressure sensor error. They can reset it but every time you touch the brakes it comes back on again, has anyone any idears please. Cheers Ian
ian1965
Re: error code
Postby SteveS » Fri Dec 13, 2013 7:55 pm
ian1965 wrote:My subaru has come up with an error on my local garages diagnostic equipment, brake boost pressure sensor error. They can reset it but every time you touch the brakes it comes back on again, has anyone any idears please. Cheers Ian
What code do you get mate?
SteveS
Re: error code
Postby ian1965 » Sat Dec 14, 2013 11:01 am
P0558
ian1965
Re: error code
Postby SteveS » Sat Dec 14, 2013 11:14 am
Wiring short to positive
Brake boost pressure sensor
Or ECM
According to Autodata
SteveS
Re: error code
Postby Alastair_H » Wed May 28, 2014 9:15 am
With a bit of searching around I have found some other information saying this is a Subaru reserved code and "P0558 = Alternator Circuit Low" this may have something to do with the replacement alternator being supplied. Both alternator's apparently have 3 pin plugs the one marked C- S (has a dummy pin) and the one marked C - S - L is the correct item. Current output levels may be different, will investigate further.
Alastair_H
Re: error code
Postby weirdfish » Wed May 28, 2014 11:50 am
So has the error code come up since you had the new alternator fitted?
weirdfish
