Blip in 3/4th when giving some beans
Postby Super si » Wed Oct 09, 2013 3:30 pm
Happened a couple of times now when I'm putting foot down on motorway or dual carriageway in 4th or 5th (not both but can't remember which) it has a little hick up at 5/5.5k. Loosing acceleration for a second & then back to normal. No bangs just the hick up & the emissions light comes on dash.....any body had same problem or know the cause? Doesn't do it driving around town only when powering through gears on motorway :cry:
Super si
Re: Blip in 3/4th when giving some beans
Postby Super si » Sat Oct 12, 2013 10:13 am
No one?
Super si
Postby Daz » Sat Oct 12, 2013 5:33 pm
hiya bud just wondered if you had it remapped after you put the decat on , or it could be that noisy dump valve you've got on causing a loss of air putting a warning light on :lol:
Daz
Postby Super si » Sun Oct 13, 2013 6:57 am
Hi pal, no didn't have it mapped with decat just a resistor fitted to prevent lights on dash. I'm not sure it will be dump valve it does it at 5/5.5rpm powering through, I was under impression that dump valve only working when you let off throttle to release boost pressure were I had foot planted. Might have to just take it to specialists
Super si
Users browsing this forum: No registered users and 17 guests
