Brakes
PostPosted: Fri Feb 08, 2013 7:46 am
by Mark WR1 102
Hi all, my nearside brakes front and rear are getting very low but the offside still has loads of pad left, has anyone had this problem before. Thanks. Mark.
Re: Brakes
PostPosted: Fri Feb 08, 2013 8:35 am
by Gary75
Mark WR1 102 wrote:Hi all, my nearside brakes front and rear are getting very low but the offside still has loads of pad left, has anyone had this problem before. Thanks. Mark.
I assume you mean offside as the outer or outboard pad on the front and rear? I would first remove the pads and make sure both pistons in both calipers are moving freely and not seized. When the pads where last changed did you or someone else bleed both nipples on the calipers front and rear? I know on single piston calipers the piston side pad does where slightly more, and i mean very slightly.
I would be more inclined to suspect a seized piston on one side, but very unlikly on both front and back at the same time? i could be wrong?
Brakes not bled properly?
Does the car pull to one side when braking hard? if so thats indicative of seized caliper sliders or pistons. ( sliders not used on the one )
Does the car suffer with any wheel wobble when braking, again points to uneven braking / disc run out etc.
Is the brake pedal firm?
My pads are worn evenly on both sides, pistons can be moved back in by thumb pressure.
Hope this helps
Re: Brakes
PostPosted: Fri Feb 08, 2013 12:59 pm
by Mark WR1 102
Hi Gary, yes very helpful thank you, yes the offside front and rear pads you can see when the wheels are still on both low, Not sure if they were bled properly last time they were changed cause I've only had the car since 22nd December last year.
Theres no pulling to one side when hard braking, No wheel wobble and the brake peddle is firm, is that still pointing to not being bled properly ? And thanks again :)
Re: Brakes
PostPosted: Fri Feb 08, 2013 4:14 pm
by Gary75
Mark WR1 102 wrote:Hi Gary, yes very helpful thank you, yes the offside front and rear pads you can see when the wheels are still on both low, Not sure if they were bled properly last time they were changed cause I've only had the car since 22nd December last year.
My first inspection would be, remove the pads and check the brake caliper pistons have free movement either side, check all four corners at the same time. Also check the pads have free movement within the caliper,if all is free i would change the pads on all four corners, then bleed the system. As you state the pads are low, so due a change anyway. Make sure all the calipers are clean, remove any brake dust build within the caliper, make sure everything is clean before fitting the pads, use some copper ease on reassembly, I use a product called Permatex extreme ceramic brake parts lubricant, i find this a better product than copper ease, this will keep everything free and moving ( dont apply grease to the pad surface though :shock: )
Re: Brakes
PostPosted: Fri Feb 08, 2013 4:29 pm
by Mark WR1 102
My first inspection would be, remove the pads and check the brake caliper pistons have free movement either side, check all four corners at the same time. Also check the pads have free movement within the caliper,if all is free i would change the pads on all four corners, then bleed the system. As you state the pads are low, so due a change anyway. Make sure all the calipers are clean, remove any brake dust build within the caliper, make sure everything is clean before fitting the pads, use some copper ease on reassembly to keep everything free and moving ( dont apply grease to the pad surface though :shock: )
Thanks Gary, will get it sorted next few weeks and post back on here let you know what the problem was, thanks.
Re: Brakes
PostPosted: Sun Feb 24, 2013 12:09 pm
by Mark WR1 102
Hi Gary sorted brakes out all the calipers were free moving, the problems was very old brake pads one was breaking up, all sorted now tho, thanks for your help :)
Re: Brakes
PostPosted: Sun Feb 24, 2013 9:52 pm
by Gary75
Mark WR1 102 wrote:Hi Gary sorted brakes out all the calipers were free moving, the problems was very old brake pads one was breaking up, all sorted now tho, thanks for your help :)
Glad you got it sorted and only the pads were the problem :thumb:
Re: Brakes
PostPosted: Tue Oct 15, 2013 9:49 am
by HMR81
anyone know the cost of replacing discs and pads on the front please?
Re: Brakes
PostPosted: Tue Oct 15, 2013 11:45 am
by Mark WR1 102
All depends what you want, front discs can be anything from £100 to £500 think standard front brembo are around £300 hope that helps.
Re: Brakes
PostPosted: Tue Oct 15, 2013 12:27 pm
by HMR81
stupidly I thought they were 300 a pair. doh.
Re: Brakes
PostPosted: Tue Oct 15, 2013 12:59 pm
by Mark WR1 102
Was it standard you are after ? I've had pagid discs and pads front for £145 but I get them at trade
Re: Brakes
PostPosted: Tue Oct 15, 2013 1:49 pm
by HMR81
well I was thinking standard to be honest
Re: Brakes
PostPosted: Tue Oct 15, 2013 2:23 pm
by asperformance
we can supply most options from OE quality through to extreme use................
0191-4103770
Re: Brakes
PostPosted: Mon Oct 28, 2013 2:37 pm
by HMR81
they are 326mm discs arent they?
Re: Brakes
PostPosted: Tue Oct 29, 2013 8:29 pm
by asperformance
326mm front and 316mm rear as std..............
Re: Brakes
PostPosted: Tue Oct 29, 2013 11:24 pm
by Megaman
AP Racing Brakes are the way to go if you are going to be doing track days, otherwise there are plenty of other better brake solutions to the oem setup which i never found very sharp :)
Re: Brakes
PostPosted: Wed Oct 30, 2013 11:21 am
by HMR81
Agree Megaman, Im changing the disc and pad for now. Love AP Racing brakes but for the odd hillclimb/sprint i just won't generate the heat to require AP's..yet.
Its something i would consider later on thats for sure. Does the AP racing kit come with Bias control? I was tempted to buy the bias control setup off a WRC car lol, but just seemed like far too much work to get it working in car.
Re: Brakes
PostPosted: Wed Oct 30, 2013 12:08 pm
by Megaman
HMR81 wrote:Agree Megaman, Im changing the disc and pad for now. Love AP Racing brakes but for the odd hillclimb/sprint i just won't generate the heat to require AP's..yet.
Nope no bias control with the AP's However you should do front and rear and not just fronts if you are going for AP's to ensure the car is stable under heavy braking.
My first tweak was goodrich braided hoses, 5.1 fluid, EBC yellow stuff pads and EBC turbo grooved discs. These transformed the cars stopping ability for normal driving conditions but on my first track day i cooked the brakes quickly and got brake fade. The yellow stuff pads are great from cold but not when hot on tracks requiring brakes to be hammered. There are now plenty of kits out there which I didnt know about or which werent available when i did mine years ago. :)
Re: Brakes
PostPosted: Wed Oct 30, 2013 12:25 pm
by HMR81
completely agree, i would do the whole car if i was going to change the brakes to AP's.
I've raced some road spec scoobies at sprints and hillclimbs and because of the duration of the event std. STI road brakes don't give you a long pedal but yes, on a track you need braided hoses, 5.1 DOT and a disc/pad combo to take the heat.
Im going to use the Tarox discs with cosworth track pads. They have a great bite from cold and take a good amount of heat, i.e. i can lap brands at a good pace for 5-6 laps before the pedal will start to go a touch long. Given that a sprint and hillclimb is in the region of 1-2 mins long they will be fine for some summer fun and should be ok on the road. I have another toy for tracks anyway, the WR1 is too nice to risk putting her on the roof lol.
Re: Brakes
PostPosted: Wed Oct 30, 2013 3:42 pm
by WR1
Whats the track toy?
Re: Brakes
PostPosted: Wed Oct 30, 2013 3:49 pm
by HMR81
250cc gearbox Kart. blows my mind everytime i drive it lol
Re: Brakes
PostPosted: Wed Oct 30, 2013 3:59 pm
by Megaman
Pics?
Re: Brakes
PostPosted: Wed Oct 30, 2013 4:14 pm
by HMR81
Ive got some at home, ill upload a few when i get chance.
Re: Brakes
PostPosted: Wed Oct 30, 2013 4:59 pm
by WR1
Cool - I was carting at Buckmore park on Monday - bit damp but a lot of fun.
