whats the best oil for the wr1
Postby davetwr1 » Tue Jan 15, 2013 7:10 pm
my car is due for its 50000 service and i wanted to know whats the best oil for the 1 as the local subaru dealership has done the last two services and i think they have used cheap oil. what are you lads running in your car ?
davetwr1
Re: whats the best oil for the wr1
Postby W1 KRB » Tue Jan 15, 2013 7:59 pm
Fuchs Titan race pro s 5-40 synthetic in my standard power 1, recommended by opie oils
W1 KRB
Postby marchar » Tue Jan 15, 2013 11:31 pm
same as above, I did Use millers v300 the time before that but it didnt like it on a few cold mornings, The fuchs has been great even after a week without use :suss:
marchar
Postby BIG"E" » Wed Jan 16, 2013 7:02 am
Millers 10/50 as supplied and recommended by Alyn at As Performance..
Give him a ring for all your needs ..
BIG"E"
Postby asperformance » Wed Jan 16, 2013 9:05 am
Marchar i think you mean MOTUL 300v.............a lot depends on actual grade used, mods, etc.
Fuchs is a much lower quality than the Millers CFS and particuarly than the new Millers CFS NT and Motul 300v...........
Postby Gary75 » Wed Jan 16, 2013 9:12 am
W1 KRB wrote:Fuchs Titan race pro s 5-40 synthetic in my standard power 1, recommended by opie oils
Yes i use the same, but in addition i use a magnetic drain plug and 6 small maganets around the filter. Hope this helps?
Postby marchar » Wed Jan 16, 2013 10:57 pm
thats the kiddie alyn, Motul 300v, The grade was 15- 50, Just rattled a couple of times when started from cold for a second or so
It was expensive, I think I paid about £120 for 6 litres and didnt even do 5000 miles on it :roll:
Probably got the wrong grade or somthing? Maybe I will try the millers next oil change :)
marchar
Postby asperformance » Thu Jan 17, 2013 9:11 am
15w50 is far more suited to a classic or heavily modded scoob.........
if you paid £120 then you bought it from the wrong place.......... :wink:
Postby Chris B » Thu Jan 17, 2013 1:39 pm
Castrol edge
Chris B
Postby marchar » Thu Jan 17, 2013 7:44 pm
I'm going to dig the receipts out and see what it cost,
6 litres cost me £97.59....... ?
marchar
Postby Megaman » Thu Jan 17, 2013 8:13 pm
I run my modified car on millers 10w60
Postby asperformance » Fri Jan 18, 2013 11:22 am
to save a few PM's, etc......
we supply/use both Millers and Motul competition oils (and their full range if needs be) and have done for the past 12yrs+..........
we always have price reductions on and will happily beat or match any other genuine quote BUT as a general rule our "normal" prices are cheaper than most others "specials"
carry genuine filters, etc. in stock and will happily post World wide if needs be 8)
Postby marchar » Fri Jan 18, 2013 10:51 pm
I'll give you a tinkle when the time comes, I'm also nearly up to full in my brakes bank too :)
marchar
Users browsing this forum: No registered users and 43 guests
