Anyone got any photos of how to remove the old ones to install new?
Users browsing this forum: No registered users and 59 guests
Fitting New Driving Lights -Anyone got any photos of how to remove the old ones to install new?
Re: Fitting New Driving Lights -Its a doddle Simon. Prize off the driving light surrounds with a suitable screwdriver. Try to protect the paintwork by wrapping some tape around it.
Once you have done this you will see that 3no stainless 6mm bolts hold them onto the bumper brackets. Give them a squirt of WD40 or something similar.These bolts have springs behind them to enable you to set the angle of the lights to your desired position. Probably best to measure how far each bolt is currently positioned so you can put them back again in the same positions. There is a plug and socket behind the lights when you pull them out. Disconnect this obviously and fitting is the reverse of removal. Good luck and hope it works smoothly. Carl.
Re: Fitting New Driving Lights -Fitted - bit of a chew on - but got it fitted in the end...
looks the bee's now.
Who is onlineUsers browsing this forum: No registered users and 59 guests |
