Does anyone know if its OK to run the engine if the air con pump has had its pressure removed.
I was swapping out various nuts and bolts in the engine bay for new shiny ones and decided I would remove the one that holds the top pipe onto the air con pump. Rather stupid in hindsight and to cut an embarrassing story short the pipe unsurprisingly broke its seal, with the result of lots of air con gas escaping very quickly.
Anyway, will I be OK to run the engine up or not.
Awaiting sarcastic comments and hopefully some helpful ones!!
Carl
Users browsing this forum: No registered users and 43 guests
