Users browsing this forum: No registered users and 54 guests
helpjust had the 1 serviced, oil/filter,new plugs, uprated fuel pump and re mapped, the problem i got is that it judders most times when pulling off at junctions sometimes when changing up it seems to have a sort of miss, and cant get no more than 50miles out of £20 petrol,, and thats not booting it,, the only way i can get it to run slightly better is to leave the petrol cap loose, could it be the mapping or wrong pump fitted, mapping was done by bob rawle??????
LBUFFIN
A mapper should be able to tap in and see whats going on, sounds like its running really rich to me or there is an ignition issue. Give someone like Adam at autotecnica a bell, he might know off the top of his head by the way its running.
Had a similar problem on my WRX recently, turned out to be no 2 cylinder coil , got it replaced and she went like a dream. Hope yours is that easy
I also had a similar problem on my previous WRX! Turned out the numpty who serviced it left one of the coils loose, which eventually fell off.
I think coil packs can come lose if the plugs are changed whilst the engine is warm. So maybe thats what happened.
How does this happen you might ask. Well im not saying that they did this, BUT maybe the garage took your car for a joy ride to try it out, followed by a few donuts in Mc Donalds car park whilst hanging out of the window, stereo cranked up to the max. Then cruised back and started to service the car whilst still warm from the car being bounced off the limiter for the past half hour... result is coil pack works loose when the car cools down overnight whilst recovering from the garage thrash. If your worried about this happening to your car get a roadhawk!
why didnt i think of that LBUFFIN
B*stards! The guy at the garage took nearly 2 hrs to do a ten mile drive back to mine, and when he dropped the car off he had his girlfriend in it too! He said she only lived down the road! Hmmmmmmmmmmmm
so why the pressure in the tank when i release the cap (only if i do the cap up tight)????? LBUFFIN
Rather than pressure, its more of a partial vaccuum, mine does it too, the sticker by the cap says release slowly.
I agree with this but car runs smoother when I have release the pressure ??? And if I leave the cap loose???think the pump maybe to big????? LBUFFIN
Who is onlineUsers browsing this forum: No registered users and 54 guests |
