Front Fog/Driving lights...HELP....!
Postby Parky78 » Mon Nov 14, 2011 5:13 pm
Hi all,
I have a quick question; I am having a bit of a nightmare with regards to my front fog lights?
Both front fog lights do not work?
I think that it is too much of a coincidence for both front fog light bulbs to break/fail at the same time?
Sorry to sound a bit stupid (I haven't actually used the fog lights before on this car), the switches on the bottom right-hand side of the dash board (fog lights, water spray etc...) light up when the headlights are on (so you can find them in the dark!). For some reason, the front fog light switch doesn't light up? I imagine it is supposed to???
This leads me to think that there could be a fault with the switch itself and not the actual bulbs?
I have had a quick visual check of the fog light fuse, this seems to be ok (I haven't put a volt meter on it though). If the fuse was suspect, would this stop the light in the switch to stop working?
Has anyone had a similar problem with their fog lights? Is this an easy thing to fix? Also, is changing the switch (if it is the switch) an easy job?
I might double check the fuse with a volt meter before I start pulling switches out. I am having visions of taking bits of dash board out, hopefully it wont be too painful!
Cheers in advance for any help, It will be much appreciated!
John
Parky78
Postby Lee190888 » Mon Nov 14, 2011 5:14 pm
Full Beam has to be on :)
424
Lee190888
Postby grahampesking » Mon Nov 14, 2011 5:39 pm
Lee is right, you need your full beam headlights on .. thats why they are called "Driving Lights" and not " Fog Lights" ..
never had any probs with mine , when you have you,r full beam on , you,r switch should light up blue
hope this helps :?
grahampesking
Postby WR 1mposter » Mon Nov 14, 2011 8:04 pm
another case of RTFM :lol:
Postby Matty WR1 » Mon Nov 14, 2011 8:12 pm
LOL!
driving lights = on with main beam with the switch pressed in next to the IC spray button
Matty WR1
Postby SteveS » Mon Nov 14, 2011 10:15 pm
An easy mistake to make, lets face it who reads the manual..............until it goes wrong :oops:
SteveS
Postby Steveyk » Tue Nov 15, 2011 1:19 pm
If you press the switch in on the dash with your lights off, nothing will happen, the switch doesn't illuminate. If your lights are on dip, nothing will happen. When you put main beam on or flash, the driving lights come on, providing the switch is depressed. The light in the switch will illuminate blue when your main beam AND driving lights are on.
On a WRX the switch turns the fog lights on, which work whenever the lights are on.
Steveyk
Postby Parky78 » Tue Nov 15, 2011 8:34 pm
Thanks everyone for your replies. I didn't realise that the main. Beam should have been on!
I have since learnt why the driving light switch doesn't illuminate. Prodrive put a "driving light" sticker over the original Subaru "Front Fog Light" switch. This sticker doesn't allow the light through to illuminate the switch? I can live with this though, I will just leave the switch on!
Thanks again for all of your comments, they are much appreciated and prevented me butchering my dashboard!
Cheers,
Joh
Parky78
Postby Loco2527 » Fri Nov 18, 2011 7:34 pm
you know, you can get the "driving lights" to come on with just dipped beams. its a simple fix:
just pop the switch out, and swap over the 2 black wires on the back of the switch. The fog lights then come on when on full beam and dipped beam, but not with sidelights on. It does cause the light on the switch to have a bit of a hissy fit tho, as the switch illuminating light is normally off, unless you go to full beam, then it comes on. but the actual green indicating light on the swich still comes on like normal when you press the switch
I found this particularly useful, because when it is actually foggy, its such a pain having main beams on at the same time as fog lights - you still can't see a bloody thing!
hope this helps anyone...
Loco2527
Postby grahampesking » Fri Nov 18, 2011 7:37 pm
Loco2527 wrote:you know, you can get the "driving lights" to come on with just dipped beams. its a simple fix:
good post buddy , it is annoying when you cant use them as actual fog lights , as u say , fuul beam just makes it harder to see
grahampesking
Postby Ant » Fri Nov 18, 2011 9:45 pm
good post buddy , it is annoying when you cant use them as actual fog lights , as u say , full beam just makes it harder to see
Not wishing to offend or upset anyone here but these are the facts, these lights are not fog lights they are driving lights ie additional mainbeam lights so as such should only come on when main beam is on, there not designed as fog lights and will give out a very different beam pattern to fog lights, if you set these up to come on with dip beam and this caused an accident by blinding an oncoming vehicles driver you could face a manslaughter charge so do yourself and everyone else a favour grow up and leave them as they are and dont try to be one of the fog lights on all the time brigade, thanks.
Ant,
Had an my99 uk classic,
Then got P1 (0329),
Then got a my00 UK Classic,
Ant
Postby Ant » Fri Nov 18, 2011 9:55 pm
Just to add we had this problem over on the P1 site a few years ago when the P1's started to fall into the hands of younger drivers suddenly every new owner was posting similer questions about getting them working on dip or as fogs, There far more usefull as driving lights anyway as fog lights are only needed two of three times a year, people driving around at night with fogs on all the time is one of my pet hates, having these on with dip beam would be like having main beam on to an oncoming driver.
Ant,
Then got P1 (0329),
Ant
Postby grahampesking » Fri Nov 18, 2011 11:31 pm
Ant wrote:Just to add we had this problem over on the P1 site a few years ago when the P1's started to fall into the hands of younger drivers suddenly every new owner was posting similer questions about getting them working on dip or as fogs, There far more usefull as driving lights anyway as fog lights are only needed two of three times a year, people driving around at night with fogs on all the time is one of my pet hates, having these on with dip beam would be like having main beam on to an oncoming driver.
Not my worry , Ive just put on driving light covers , :finger:
grahampesking
Postby Steveyk » Sat Nov 19, 2011 12:07 am
Not wishing to offend or upset anyone here but these are the facts, these lights are not fog lights they are driving lights ie additional mainbeam lights so as such should only come on when main beam is on, there not designed as fog lights and will give out a very different beam pattern to fog lights, if you set these up to come on with dip beam and this caused an accident by blinding an oncoming vehicles driver you could face a manslaughter charge so do yourself and everyone else a favour grow up and leave them as they are and dont try to be one of the fog lights on all the time brigade, thanks.[/quote]
Well said sir, they aren't designed as fog lights and are essentially two extra main beams in the bumper. Useful for 'reminding' people they have their fogs on in June, but better left as PIAA intended.
Steveyk
Postby Loco2527 » Sat Nov 19, 2011 12:57 am
wow, when I popped my post up on how to do it, I didn't expect any replys like that!!
pretty certain I made it clear that they are helpful when it's foggy... Maybe i didn't make that part clear enough... I don't drive round like a dick with my "driving lights" on all the time. I use them as fog lights, which I only turn on when it is actually foggy. I find main beam plenty ample for just driving around from day to day, but they are next to useless when it is actually foggy, like it is quite a lot at the moment. is that clear enough now?
I am surprised that this has drawn so much attention. Next thing you know, people will start kicking off about people running full decat exhausts or something like that.
"oh no, all you naughty boys out there..." :roll:
Loco2527
Postby Ant » Sat Nov 19, 2011 8:51 am
Loco2527 wrote:wow, when I popped my post up on how to do it, I didn't expect any replys like that!!
So your putting a set of main beams on when its foggy, what do you think that will do to the people coming the other way??? as I said driving lights cannot be used as fog lights as the beam patern is completely different.
Ant,
Then got P1 (0329),
Ant
Postby Loco2527 » Sat Nov 19, 2011 11:35 am
For a start, I am pretty certain there isn't much difference between driving lights in terms of brightness or glare or anything like that, because there has already been plenty of posts on this thread talking about how they get pissed off with people driving with their FOG lights on (not driving lights in all those cases...). Plus, is there actually any difference between WR1 driving lights, and aftermarket fog lights you can get for other blobeyes?
Secondly, when I see another car coming, I turn them off, just as you would do with full beam when driving on a clear night, or even more appropriately, just as you would do with your rear fog light when someone drives up behind you.
Am I just being crazy here, or do people seem to be picking a fight for the sake of it?! This thread has gone from a simple helpful tip that is potentially going to help you when you can barely see 20 yards in front of you, to becoming a murderer!
I think someone said earlier that people who change a couple of wires over on a switch in order to benefit your visibility in poor conditions, should "grow up". How ridiculous is that?! Well, I'm sorry. I didn't realise that people don't have common sense any more, and as soon as you mention you can put some extra lights on, it means that everyone is going to start driving round with them on, all the time, with no consideration for other drivers...
I mentioned a mod that may end up helping people. If you don't like it, don't do it to your own car.
Pretty "grown up" answer there, I think...
Loco2527
Postby grahampesking » Sat Nov 19, 2011 12:12 pm
its not hard to turn off you,r full beam when you see another car coming , pretty simple really :roll:
grahampesking
Postby chiroman » Sat Nov 19, 2011 1:01 pm
What a hoot.
Proposal. As the WR1 "Driving Lights" are becoming harder to source remove existing ones and replace with "Fog Lights" which are aimed as kerb finders, tinker with the wiring so they are on with main and dip beams.
Store or sell on the existing PIAA "Driving Lights".
Install HID's to main and dip lights. With the HID's the mediocre "Driving Lights" are completely redundant.
chiroman
Postby Loco2527 » Sat Nov 19, 2011 1:21 pm
This will make you laugh chiroman...
On the HID front, I am pretty certain it used to be illegal to have HID headlights if you didn't have headlight washer jets fitted to your car (I think it was a stupid EU rule).
Was that the case, and if so, has the law been changed to allow them now? Because if it's still illegal, people will have just as much of a problem with your solution as they would with mine. Can anyone shine any light (pardon the pun...) on this? Haha
Loco2527
Postby Parky78 » Sat Nov 19, 2011 10:06 pm
In the words of the late Jimmy Saville "now then, now then"! I feel that this thread went t*ts-up when a certain contributor started to assume/stereotype!
I don't like to stereotype. I am sure we are all responsible drivers (I don't mean to stereotype lol).
I find it quite imaginative by starting a thread about potential light switch problems, it could escalate to irresponsibility and manslaughter?! I might need some counciling before I use my driving lights again just encase I deviate from the correct rules of engagement (R.O.E)! LoL!
I might start a thread about a car mat retaining clip (might result in a food fight? lol).
In seriousness, thank you all for your help and info regarding my original problem, it is much appreciated. This is a great forum, with invaluable info from everyone.
Cheers all.
Parky78
Postby WR1 Bro » Sat Nov 19, 2011 11:42 pm
Parky78 wrote:In the words of the late Jimmy Saville "now then, now then"! I feel that this thread went t*ts-up when a certain contributor started to assume/stereotype!
Cheers all.
Great attitude and response with a smile.
Watch those mat clips, I've once seen them spring up and nearly taken an eye out. Be warned.
Postby Matty WR1 » Sun Nov 20, 2011 1:23 am
Good man, love it!
What about a topic about setting the shift change light and how to stop the bugger from beeping! Or is that just mine lol?
Cheers all.
Matty WR1
Postby chiroman » Mon Nov 21, 2011 5:38 pm
So does anyone actually use their "driving lights"?
As for the HID's there's loads of debates on forums as to whether the aftermarket ones are legal. Apparently the OEM requires jet washers and auto self levelling, maybe even projector reflectors. Mine has passed all MOT's no questions asked.
chiroman
Postby Matty WR1 » Mon Nov 21, 2011 9:33 pm
which clown deleted my typing then eh :evil:
Matty WR1
Postby Steveyk » Tue Nov 22, 2011 9:11 am
chiroman wrote:So does anyone actually use their "driving lights"?
I thought only Xenon lights needed washers etc, all new Honda Civics have HID headlights and I don't think they have washers but I might be wrong..?
And I do use the driving lights on the lanes round me, they make a big difference to the edges of the road, hedges and verges etc.
Has anyone got uprated bulbs that aren't HID?
Steveyk
Postby EK563 » Sat Mar 03, 2012 8:59 pm
wow after reading this thread im scared to ask the question.
i know of a few wr1's breaking and would like to convert a wrx to have driving lights.
what parts would i need to do this.
i have spare driving lights so they are sorted. im guessing the switch is different because of the blue LED. and again and this is a big guess. the relay is different.
anyone shed some light, thanks.
EK563
Postby EK563 » Tue Mar 06, 2012 9:55 am
is it the fact that i asked a bone question
or
does no one know
EK563
Postby asperformance » Tue Mar 06, 2012 10:32 am
the wiring, etc. is totally different, may well be easier to simply buy a new PIAA complete 'kit'
or remove it in its entirety from a broken WR1........
Postby EK563 » Tue Mar 06, 2012 12:12 pm
thanks mate. will sack the upgrade :lol:
EK563
