Users browsing this forum: No registered users and 46 guests
Locating ECUI need the serial No of my Simtek and ive been told its in the passenger footwell? had a look behind the kick plate but cant see owt?
Re: Locating ECU
Mark why do you need the serial no ? It's behind the carpet then remove steel case 10mm bolts, iirc the serial no should be on the ecu itself ! 2007 BMW M5
Cheers Martin your a star
I'm having Duncan do a few tweaks on it, cold start problem, the needle on the boost gauge is trying to going of the scale so he said he needs its serial number
I take it Duncan did'nt map it originally ?
Some mappers just dont want to show there maps to others. 2007 BMW M5
you need the Simtek serial number if anyone other than the original mapper is to tweak it.............
Simtek then supply an access code as its not a simple generic software ASPerformance
Who is onlineUsers browsing this forum: No registered users and 46 guests |
