Boot won't open
Boot won't open
Postby delrodney » Tue Jan 18, 2011 10:26 am
Boot won't open with key (key won't turn in lock) and the internal release failed at w/end too. Sounds as though the cable linkage has uncoupled itself somehow.
Before I get it booked into Keith Price at Abergavenny, has anyone had same failure? If so, any idea if it can be a DIY fix?
Thanks
Trev
Your ego is writing cheques your body can't cash!
WR #47
delrodney
Re: Boot won't open
Postby John Mc » Tue Jan 18, 2011 10:34 am
delrodney wrote:Boot won't open with key (key won't turn in lock) and the internal release failed at w/end too. Sounds as though the cable linkage has uncoupled itself somehow.
Thanks
There is an override "switch" on the internal side of the boot lock... if you put this into the override position (maybe accidentally) you are fooked if your key doesn't work (this happened to me...)
You could try dismantling the interior rear seats and get into the boot that way to see if the override switch has been flicked into override position OR drill the lock out and replace the lock (unless you know a good locksmith that can pick them!)
Postby delrodney » Tue Jan 18, 2011 10:54 am
Thanks for info.
I don't believe I've caught the internal override switch in the boot.
When I pull the internal release by pilot seat, I can hear cable moving, but it's clearly not connected to the release mechanism.
Seat dismantling...............mmmmm.......not sure I'm up for that!
Trev
WR #47
delrodney
Postby CAVEMAN » Tue Jan 18, 2011 11:33 am
The only way back there is to remove your rear seats.
This is really simple - just 2 bolts on the lower section, and then 3 or 4 on the upper section. You can leave your seat belts alone, so no worries there.
Just gotta be careful trying to get top hooks back in again, as the rear window got in my way of a clear view.
Simple 20 min job really...
if you can't be arsed doing that then try flippin down the centre console and shine a torch back there to see if the cable is still attached or anything obvious like that.
Postby delrodney » Tue Jan 18, 2011 11:42 am
Thanks Caveman.
I will hope for good weather at w/end and get the socket set out. :lol:
Trev
WR #47
delrodney
Postby Bonovox » Tue Jan 18, 2011 12:49 pm
I think your problem there is you have over filled the boot.
I find I can only carry one corpse at a time without the bodies getting in the way of the hinges and cables. :lol: :wink:
Bonovox
Postby MaverickUK82 » Tue Jan 18, 2011 12:53 pm
Could you not operate the switch from the ski hatch? Maybe at least be able to see it from there?
Postby John Mc » Tue Jan 18, 2011 6:32 pm
[quote="MaverickUK82"]Could you not operate the switch from the ski hatch? Maybe at least be able to see it from there?[/quote
If you had Mr Tickle arms I'm sure you could :lol:
Postby delrodney » Mon Feb 14, 2011 3:37 pm
removed back seat as suggested earlier in thread.
it was pretty easy to do tbh.
now sorted.
many thanks.
:thumb:
Trev
WR #47
delrodney
Users browsing this forum: No registered users and 52 guests
