Fault code
Fault code
Postby Darren MacD » Tue Nov 23, 2010 9:41 pm
My engine managment light keeps coming on i took it to subaru and they plugged it in to the computer and it said Code for Subaru PO458 cainster purge control solenoid valve circuit low. They changed out the solenoid and code still came up has anyone had this problem before any help would be appreciated cheers darren
Darren MacD
Postby The Swede » Wed Nov 24, 2010 1:02 am
Oioi, that's the beginning of the end.
I'd recommend to sell the car asap. :?
If you get £7000, go for it.
Postby Darren MacD » Wed Nov 24, 2010 8:31 pm
The Swede wrote:Oioi, that's the beginning of the end.
WHAT YOU ON ABOUT DUDE !!!!
Darren MacD
Postby MaverickUK82 » Wed Nov 24, 2010 11:31 pm
The PO458 code is very grave indeed, especially with the WR1 :!:
Postby The Swede » Thu Nov 25, 2010 11:25 pm
I'd keep it quiet and sell it on autotrader.
It can still last 1500 miles, but it could also just last another 200m.
Subaru and Prodrive always managed to keep the construction fault really quiet which wasn't too difficult given the low numbers the WR1 was produced in. :?
Postby John Mc » Fri Nov 26, 2010 8:08 am
The Swede wrote:I'd keep it quiet and sell it on autotrader.
Couldn't you just replace whichever part is faulty? I'm assuming that the management system is flagging up a part or parts is/are about to fail??
Re: Fault code
Postby zedder » Fri Nov 26, 2010 12:46 pm
Darren MacD wrote:My engine managment light keeps coming on i took it to subaru and they plugged it in to the computer and it said Code for Subaru PO458 cainster purge control solenoid valve circuit low. They changed out the solenoid and code still came up has anyone had this problem before any help would be appreciated cheers darren
this may help
P0458 = Evaporative Emission System Purge Control Valve Circuit High
You have to replace your "Leak Detection Pump". When the solenoid within this pump is not active, it throws this code.
A Leak Detection Pump is a small air pump. It pressurizes the EVAP & Fuel system to make sure there are no leaks. This ensures that no harmful vapors are escaping to the atmosphere. It is used by the PCM. This is actually a pretty small pump and doesn't have a lot of pressure behind it so they do fail pretty easily. And....this is a part of the emissions system, so yes...It can make you fail your state inspection
Read more: http://wiki.answers.com/Q/How_do_you_fi ... z16OK5EEuN
zedder
Postby MaverickUK82 » Fri Nov 26, 2010 1:42 pm
Good post Zedder :thumb:
Re: Fault code
Postby Darren MacD » Fri Nov 26, 2010 8:39 pm
this may help
Cheers for the help m8 much appreciated :thumb:
Darren MacD
Postby Micktype WR1 » Sat Nov 27, 2010 4:23 pm
Top man Zedder !
Micktype WR1
Postby The Swede » Sat Nov 27, 2010 7:34 pm
You could. But where's the fun in replacing a 12 quid part if you can change the whole car? :lol:
Postby Darren MacD » Sat Nov 27, 2010 9:19 pm
Alright thr Swede are you tryin to whynd me up dude am confussed
Darren MacD
Postby The Swede » Sun Nov 28, 2010 12:20 am
Not my style, mate. Bloody serious. :?
Postby Bonovox » Sun Nov 28, 2010 12:52 am
Err Swede you dropped your key!
Image :lol:
Bonovox
