clutchhi my clutch is jerky when i first pull away is it normal the faster i go the better it gets
is it slipping at all?
If from a standstill you put it in 4th and rev it and release gently does the car stall or does it squeak and pick up speed?
Does this actually work? UK TURBO...SOLD
P1 976.....SOLD WR1 043.... SOLD M3 CAB (E46) ..SOLD EVO IX MR FQ-360 (running 410/430)
Setting off normally not thrashing it in 4th gear should stall the car...
if it squeaks and picks up speed slowly then chances are the clutch is slipping...
My clutch also judders from a standstill or trying to reverse. Tried a full-beans start and ended up with whiplash and the smell of a tortured clutch. I know these aren't the most refined cars in the world but my old WRX was much smoother. Seems to me anything much below 3000rpm trying to pull away and it judders, above this it's fine.
I do not notice this with mine.
How much damage do you reckon a 'full beans launch' as you put it does to the clutch?
You have to drive them gently before 3k rpm and not just floor it with the oem map - if i booted mine from low rpm in low gears it used to almost kangeroo. Solution = Remap from Dynamix
Re: Clutch pedel high.
give us a clue
Been for an early Wetherspoons session I reckon! Previously:
Subaru Impreza WRX (P95 CJH) Subaru Impreza WRX (DV52 LJZ) Subaru Impreza WRX STI WR1#131(VE04 LUW) Subaru Impreza STI Hawkeye Spec C (YD06 NGT) Subaru Impreza 22B #377 (S22BHU) Now: Subaru Impreza STI Hawkeye Spec C Type RA
Clutch pedel high.Can it be let off, easy it's not slipping,it just feel right.THe car no is 379.
Who is onlineUsers browsing this forum: No registered users and 21 guests |
