tyre wear
tyre wear
Postby WR1 STB » Mon Jul 12, 2010 10:42 am
Hello folks just wondering if anyone has ever had the same problem as myself on there 1. My rear driver side tyre has worn down in the middle section below the legal limit but the ouside areas have plenty of tread on. I have had the rear shocks knocking a bit but have used the wd40 fix which has taken the noise away and the car handles fine. Could the shocks be the reason? The passenger rear tread is fine.
WR1 STB
Postby WR1 Bro » Mon Jul 12, 2010 10:46 am
What tyre pressure are you running?
Postby John Mc » Mon Jul 12, 2010 11:24 am
Sounds like an over inflated tyre possibly if the middle is worn...
Postby WR1 Bro » Mon Jul 12, 2010 11:52 am
Yep John, that is what I was thinking. People tend to run higher pressures on track to save tyre edge
Postby WR1 STB » Mon Jul 12, 2010 4:09 pm
cheers lads my pressure was not good. But seems strange as when checking the owners manual for correct pressure there was a bit about uneven wear which stated that wear in the center of the tyre means that there is too much pressure. On checking my pressure i found i was 25psi all round. I am now up to 31psi at the rear and 33psi at the front. Hope this doesnt make it worse! :shock:
WR1 STB
Postby Thomo no 11 » Mon Jul 12, 2010 7:43 pm
WR1 STB wrote:cheers lads my pressure was not good. But seems strange as when checking the owners manual for correct pressure there was a bit about uneven wear which stated that wear in the center of the tyre means that there is too much pressure. On checking my pressure i found i was 25psi all round. I am now up to 31psi at the rear and 33psi at the front. Hope this doesnt make it worse! :shock:
it wont make the tyre wear worse but myself I wouldnt have 33psi at the front & 31psi at the back, id have it the other way round for better grip on handling when cornering.
Thomo no 11
