Nearside indicator problem?
Sun Mar 28, 2010 4:21 pm
by huzzy
My front drivers side indicator won't light up. There is nothing wrong with the bulb or the fuse as I have swapped them over and they are fine.
When I am in the car and indicating right the 'ticker' and 'blinker' goes twice as fast?
What could the problem be?
Sun Mar 28, 2010 6:14 pm
by JAMIE MEARS
NOT A RELAY PROBLEM IS IT MATE
Sun Mar 28, 2010 6:33 pm
by mark t
hi mate,
thats the classic sign that you have a bulb out.are you sure its the front bulb if you swapped them over and its still blinking fast check your other bulbs.good luck mate.mark
Sun Mar 28, 2010 6:55 pm
by huzzy
Not sure if it's the relay I'll have a check tomorrow.
Definately not the bulb that's knackered as I put it in the offside indicator and it was fine in there.
All abit odd to me.
6 years of Scooby ownership and this is the first thing I've had go tits up!
Sun Mar 28, 2010 7:24 pm
by Foley
When it blinks twice as fast thats it telling you the bulb is fooked,
Mon Mar 29, 2010 9:03 am
by WR 1mposter
bad earth or dirty connection
Sat Apr 17, 2010 11:03 am
by huzzy
I've still got the problem. I swapped over the relay and bulb and still nothing. I disconnected and reconnected the battery and tried it and it worked once!
It doesn't work on hazards or when locking or opening the car either.
I have even taken the headlight out and had a look at all connections, all seems fine there.
Sat Apr 17, 2010 12:21 pm
by Foley
huzzy wrote:I've still got the problem. I swapped over the relay and bulb and still nothing. I disconnected and reconnected the battery and tried it and it worked once!
Looks like you'll need to take it to a auto electrician, May be a problem with the relay,
Sat Apr 17, 2010 1:28 pm
by John Mc
Have you checked the wires to the indicator and that there is actually power reaching the lamp (and also a continuity back to the negative terminal)?
Sat Apr 17, 2010 1:41 pm
by huzzy
John Mc Tiddler (Dogging Expert) wrote:Have you checked the wires to the indicator and that there is actually power reaching the lamp (and also a continuity back to the negative terminal)?
That's all a little bit above me i'm afraid. It's off to Subaru next month anyway so I'll get them to have a look.
Cheers for the replys though Gents.
