Changing the OIL any help to give.??
Postby M9JOC » Sat Jan 16, 2010 12:59 pm
With regards too changing the oil is there any advise that people have from experiance. Have done this on most of my cars but all of them have their own quirks.
98 DC2 Integra type R
00 Audi TT 180 Coupe
03 DC5 Integra typeR
02 Alfa spider V6
01 Honda s2000
03 Audi TT 225 roadster
02 Porsche Boxster S
06 porsche Cayman
04 Subaru Impreza STi WR1
Now:
07 BMW Z4M
M9JOC
Postby rocko » Sat Jan 16, 2010 1:44 pm
Easy bud .. prob the hardest thing is the plastic try under neath if yours is still on .. bugger to get off .. Then the oil filter .. but easy to get to .. You may need a filter Grab thing to reliese
But YOU MUST PRIME OIL FILTER before fitting the new one
Smimple really.. If you have done other cars .. common sence
1- warm the engine up
2- undo the filler cap
3- drain oil
4- undo filter drain off
5- fit new sump plug copper washer
6- Prime filter and smear oil on rubber o ring re fit
7- replace oil .. to dip stick level
8- run for 1 min to get the oil around the engine ..then swtich off .. leave for 2 mins then cheak oil and top up if needed ..
9- check for leaks
Job done Piss take Comments Welcome :thumb:
rocko
Postby Dipsy » Sat Jan 16, 2010 2:26 pm
rocko wrote:Easy bud .. prob the hardest thing is the plastic try under neath if yours is still on .. bugger to get off .. Then the oil filter .. but easy to get to .. You may need a filter Grab thing to reliese
3- drain oil
9- check for leaks
Thats the why i get the garage i use to do a oil change on my car .I would do it my self if i had the use of a ramp
05 REG JDM Sti zl
Dipsy
Postby rocko » Sat Jan 16, 2010 2:29 pm
But if you doin it to save money from a dealer dont bother its the stamp you need really to keep the service history up ..
i only do it in between services .. so the oil is changed every 2500 miles
rocko
Postby Dipsy » Sat Jan 16, 2010 3:02 pm
rocko wrote:But if you doin it to save money from a dealer dont bother its the stamp you need really to keep the service history up ..
This is a specialist i use. I stand and watch them do it aswell and keep all the bill's to show it been serviced .I just did spark plugs and fuel filter my self .I don't trust other's workmanship on my car ie they don't take care of people property to a high standard
05 REG JDM Sti zl
Dipsy
Postby M9JOC » Sat Jan 16, 2010 3:24 pm
rocko wrote:5- fit new sump plug copper washer
what is this and where from?? sizes etc
02 Alfa spider V6
01 Honda s2000
06 porsche Cayman
Now:
07 BMW Z4M
M9JOC
Postby rocko » Sat Jan 16, 2010 3:28 pm
Not so sure mate .. when i buy a filter from RCM it comes with a washer taped to the box ..
Result
rocko
Postby Dipsy » Sat Jan 16, 2010 3:31 pm
I got a copper sump plug washer supplied with a blue print oil filter from import car parts .The copper washer fits over the threads of sump plug
05 REG JDM Sti zl
Dipsy
Postby M9JOC » Sat Jan 16, 2010 3:34 pm
Its a K+N filter i never opened box possibly inside it then Infact havent opened its packaging yet to see the box.
Cheers Lad.
02 Alfa spider V6
01 Honda s2000
06 porsche Cayman
Now:
07 BMW Z4M
M9JOC
