Performance Creations Mudflaps.
Fri Jan 15, 2010 4:31 pm
by huzzy
I've just tried fitting a set to my car. Has anybody else successfully fitted a set?
I'm having trouble self tapping the final screw to the chassis, tried drilling it. Took the wheel off to try and drill without doing it so awkwardly and still couldn't get the screw in.
Anybody with any advice?
Fri Jan 15, 2010 7:23 pm
by huzzy
Heres an idea, I'll use a High Speed Steel drill bit to drill it instead of using a wood drill bit!
The wonders of Google.
Fri Jan 15, 2010 7:51 pm
by Bonovox
huzzy wrote:Heres an idea, I'll use a High Speed Steel drill bit to drill it instead of using a wood drill bit!
remember not to fasten them on with nails
Fri Jan 15, 2010 9:04 pm
by eck
Bonovox wrote:huzzy wrote:Heres an idea, I'll use a High Speed Steel drill bit to drill it instead of using a wood drill bit!
Should have just used Surerglue, no drilling required
Sat Jan 16, 2010 10:46 am
by huzzy
Now fitted after acquiring the correct drill piece and I must say they look the dogs.
Highly recommended.
Sat Jan 16, 2010 10:51 am
by Azyman
D I Y SoS
Sun Jan 17, 2010 3:47 pm
by huzzy
And here they are:
Sun Jan 17, 2010 6:37 pm
by Foley
They look good but i think they stick out to much at the sides, imo
Sun Jan 17, 2010 9:03 pm
by John Mc
Foley wrote:They look good but i think they stick out to much at the sides, imo
I've got the same ones, I don't think mine stick out that much... I can't remember if there was a front and rear set or whether they were the same?!
Sun Jan 17, 2010 9:35 pm
by Clark
look fine to me. After all, you want them to stick out a bit otherwise they wont do their job very well...
