6 speed DCCD on a WRX
Postby 500tie » Thu Nov 12, 2009 4:49 pm
Does anybody know if i would be able to fit the above to my WRX300 which currently has the 5speed in it.
I know i would have to change the clutch and flywheel but i don't know if the actual gearbox would fit.
Any help is a aprecated
Sooty,
Or a spec D
500tie
Postby Gee Wr1 » Thu Nov 12, 2009 6:44 pm
It should fit as they are the same car more or less, same engine block same chassis so should swap ok. You might need to change your front & rear diffs though as i'm sure the sti's are different to wrx's.
Best person on here to ask is WUZ as he does these kinda swaps & mods & has far more knowledge than i ever will about what fits what when it comes to scoobs. Drop him a pm & ask.
Postby 500tie » Thu Nov 12, 2009 7:25 pm
Nice one thanks gee
Sooty,
Or a spec D
500tie
Postby WUZ » Thu Nov 12, 2009 11:08 pm
PM returned..
Forgot to say that if the DCCD box is 2006 - and is a UK box.... you'll be fine :D
WUZ
Postby asperformance » Sat Nov 14, 2009 9:42 am
you would obviously have to fit some form of control for the DCCD as the WRX doesn't have anything as std.............
Postby The Swede » Sat Nov 14, 2009 11:36 am
asperformance wrote:you would obviously have to fit some form of control for the DCCD as the WRX doesn't have anything as std.............
Is there no cut out in the trim to fit the button?
If there isn't one, then swap the console for one of an STi.
Postby 500tie » Sat Nov 14, 2009 12:12 pm
yea ive got the interior from a hawkeye in mine and it had the 2 spaces by the handbrake for the switches so thats not a problem, all i have to do is find someone to fit one for me oh yea i need to buy one too.
Sooty,
Or a spec D
500tie
Postby asperformance » Thu Nov 19, 2009 2:31 pm
no what i meant was you would need all the electronic control incl. buttons, not just somewhere to put the switch inside........................ 8)
Postby WR1 Bro » Thu Nov 19, 2009 2:43 pm
Classic Swede moment.
Postby Autotecnica » Thu Nov 19, 2009 5:01 pm
wire up a classic dccd controller or better option would be buying a neetroninics dccd controller.
you will have to have a 6 speed prop and a 180 rear diff, clutch flywheel possibly starter motor, linkage and knob!
lots of subaru breakers sell kits, around £2000-£2500 for the kit.
non dccd between £1500-£1800.
Autotecnica
Postby WUZ » Thu Nov 19, 2009 9:15 pm
5-Speed Flywheel and starter motor will retro-fit into the 6-speed box.
WUZ
