WR1 emissions failure
Postby Sprout » Thu Nov 05, 2009 5:39 pm
Looking for advice/help - I was told my WR1 was totally standard, but failed the MOT today on emissions - the garage say it has been de-catted, hence the failure. Is there any way of passing the MOT other than having to buy a new exhaust system with a cat??
Thanks in advance
Sprout
Postby Gee Wr1 » Thu Nov 05, 2009 6:07 pm
There is only one cat in the original wr1 system its in the downpipe, easy enough to check if its there yourself just open bonnet & look at the pipe coming from the back of the turbo. If the cat is still in place you should see this
The white heatproof material you see is covering the cat.
If its not there did it fail by much? There are additives you can put in your fuel that will reduce emissions a bit like Millers Eco Max, but if it was way over then that won't help much.
Postby Sprout » Thu Nov 05, 2009 7:47 pm
Cheers - not sure by how much it failed by. Assuming I need a replacement, anyone recommend an aftermarket down pipe with sports cat?? Subaru quoted £580 from them!!
Sprout
Postby rocko » Thu Nov 05, 2009 7:55 pm
Scooby world do a 100 cell cat
But If i was you GO De cat A nice 3" full system
RCM Or Miltek
rocko
Postby Sprout » Thu Nov 05, 2009 8:05 pm
rocko wrote:Scooby world do a 100 cell cat
RCM Or Miltek
Thats the problem - it is de-cat apparently but failing the MOT because of it.
Sprout
Postby John Mc » Thu Nov 05, 2009 9:07 pm
I am sure there are people who will pass it!! :wink:
Postby Ant » Thu Nov 05, 2009 10:31 pm
Make sure there not just failing it because the second cat has been removed as this is removed when the ppp was fitted, ie make sure it is because the emissions are actually too high and not just that the second cat has been removed. The first thing to do as others state is to see if the first cat in the downpipe is fitted or not.
Ant,
Had an my99 uk classic,
Then got P1 (0329),
Then got a my00 UK Classic,
Ant
Postby asperformance » Fri Nov 06, 2009 10:44 am
the problem with most sports cat is that they need to be HOT................
never had any issues with a pukka Prodrive sports cat and emissions, but have had various problems with the cheap 100CEL ones
Postby WUZ » Sat Nov 07, 2009 10:24 am
Toattly agree with Alyn above. Prodrive Sportscat will not be an issue if it is HOT.
Take it for a HARD run then drop it off to the MOT guys and test it then....... should be fine :)
WUZ
Postby The Swede » Sat Nov 07, 2009 10:59 am
I don't see what the issue is with de-cat. Half the scoobs and Evo drive around without cat.
You don't need another cat, you need another MOT station.
Also, the car doesn't really need to fail the MOT test because of the decat. Some cars, if they run well, will get low enough emissions to pass the test without cat.
Postby Foley » Sat Nov 07, 2009 6:55 pm
Mines failed with the prodrive sports cat,
The mot tester took it a good run and pass no probs when hot,
Foley
Postby WR 1mposter » Sun Nov 08, 2009 5:08 pm
The Swede wrote:I don't see what the issue is with de-cat. Half the scoobs and Evo drive around without cat.
Our car failed on emission's last time round ....just !
no cat fitted either I suspect a good blast before it would pass :lol:
Postby WUZ » Sun Nov 08, 2009 6:59 pm
Sorry for asking but how will taking a DECAT WR1 for a good blast prior to the MOT test make it pass emissions.............................. :?:
WUZ
Postby Megaman » Sun Nov 08, 2009 7:27 pm
Foley wrote:Mines failed with the prodrive sports cat,
Not sure i like the sound of the mot tester taking my car out for a spin on hos own... :shock:
Postby Foley » Sun Nov 08, 2009 7:57 pm
Yer he probs kicked it's c*nt in :lol: Was probs fine and that was an excuse to take the wr1 a spin,
Well thats what i would do if i had someone elses car lol
Foley
Users browsing this forum: No registered users and 23 guests
