Still got a water leakI have a water leak coming from somewhere around the turbo. I cant exactly seeb where it is coming from. The water is running down the seam of the exhaust manifold. any ideas ? Thanks
water cooling pipes on the turbo, probably copper washers not sealing or banjo bolts lose.
I Replaced all the copper washers , on the water and the oil. It doesn't appear to be coming from the banjo bolts
no mate, try finding where the leak is coming from, if the copper washers need changing ones from a plumbers supplier will be fine, its only hot water after all.
Unfortunately you won't find copper washers at any plumbers merchants.
have you damaged the rubber link pipe from the head take-off to the turbo???
Who is onlineUsers browsing this forum: No registered users and 45 guests |
