how to change coolant ?
Posted: Sat Sep 12, 2009 8:34 am
Thanks to all for there help/advice so far, one last thing. What is the best place to drain the coolant from ? and where is the best place to fill it from ? Thanks
ROSSCO wrote:Thanks to all for there help/advice so far, one last thing. What is the best place to drain the coolant from ? and where is the best place to fill it from ? Thanks
WUZ wrote:Drain plug for radiator is located under front Drivers side of Radiator (butterfly cap) remove top of radiator and Header Tank, then open plug......................
Foley wrote:WUZ wrote:Drain plug for radiator is located under front Drivers side of Radiator (butterfly cap) remove top of radiator and Header Tank, then open plug......................
This man is full of top advice
WR1 guru!!!
Clark wrote:Foley wrote:WUZ wrote:Drain plug for radiator is located under front Drivers side of Radiator (butterfly cap) remove top of radiator and Header Tank, then open plug......................
WR1 guru!!!
I dont trust anyone else with my car other than Wuz
