any ideas how to get the oil pipe back on (bottom of turbo)
Wed Sep 09, 2009 6:38 pm
by ROSSCO
I have been looking at how im going to put my turbo back in. How do you get the oil pipe back on the bottom of the turbo as there s not much space, any idea's , thanks
Thu Sep 10, 2009 7:08 am
by CAVEMAN
taken directly from the Haynes manual - 'Re-Fitting is the reverse of removal'
How f*cking useful is that? Sorry mate, but I don't know either...
can you take the other end of the pipe off, then fit the turbo bit whilst its out of the engine...maybe the other end is easier to fit once the turbo is back in place?
Thu Sep 10, 2009 8:52 am
by asperformance
we always leave the flexible pipe on the turbo and its a case of (simply LOL) sliding it on as you gently lower the turbo on the studs..........
Fri Sep 11, 2009 6:48 pm
by ROSSCO
managed to get the pipe to slide in, cant get the clip on it though, do i need it ? thanks
:D
Fri Sep 11, 2009 9:55 pm
by WUZ
Do it like Alyn says....................
Its only a drain and so is not subject to Positvei pressure so you'll be ok without 1 of the 2 spring clips removed.
