Fuel PumpIs the walbro 255 fuel pump fitted to the 1 as standard?
IF IN DOUT, FLAT OUT!!!
COLIN McRAE R.I.P
Yeh mate should be .. but get it cheaked i heard that they never changed or fitted 255 on all of them !
my tunner cheaked mine was ok
they need replacing quite regularly anyways so worth putting a new one in just incase.
Easy to do, just whip out lower rear seats and swap over the pumps...10 min job.
That simple? is it the same sort of idea as a central heating pump to a boiler? 98 DC2 Integra type R
00 Audi TT 180 Coupe 03 DC5 Integra typeR 02 Alfa spider V6 01 Honda s2000 03 Audi TT 225 roadster 02 Porsche Boxster S 06 porsche Cayman 04 Subaru Impreza STi WR1 Now: 07 BMW Z4M
It takes about 2 mins to get the lower bit of your rear seat out...take off the plastic cover and you will see the top of the pump assembly bolted to the fuel tank.
It is just a fluid pump like any other...so if you are careful and don't smoke then all will be fine. Never changed a boiler pump, but would imagine it is similar... Best bet is to get the part first, then you can see all the connections to it, so you can see what bits you need to disconnect from the old pump. It should come with the 'tea bag' filter and be almost a complete swap over.
Who is onlineUsers browsing this forum: No registered users and 20 guests |
