De-Tango/Condensation...How is the best way to combat condensation when de-tango-ing the lights?
They will only have condensation in them if they have water in them.
There is no vacuum in there as there needs to be the hole for the bulb to poke through. Just make sure you do this in a fairly clean environment. If you are worried then before you put the 2 halves back together, use the heat gun to help get rid of any moisture that could be inside the light cluster.
This is most probably a stupid question, but I assume I need orange bulbs for this?
What's recommended...?
You can get mirrored bulbs, so they don't look like a orange pimple Or if they not still available are the bulbs in the back light the same ! dont know cos I've never had to change one ! 2007 BMW M5
http://www.priracing.com/product.php/17 ... lbs--pair-
http://www.care4car.com/productdisplay/ ... Bulbs.html a couple to choose from just remember they may be push fit not be the bayonet type 2007 BMW M5
Cool...
So, do I need push fit or bayonet? Don't really want to rip my headlights out and find I have the wrong bulbs...
You don't have to rip your headlight out to change them so check first before you buy ! just found this for you http://www.priracing.com/product.php/17 ... ulb--pair- 2007 BMW M5
Yep! they are the ones alright! gonna have a look tonight to see whether push or bayonet!...
100% push-type...
it is a Subaru so anything you previously know is all out the window. Heck even the fuses are non-standard size!!
Who is onlineUsers browsing this forum: No registered users and 21 guests |
