WR1 Standard Stereo and Speakers...
Postby MaverickUK82 » Thu Jun 11, 2009 9:02 pm
Hi Guys,
What are the standard stereo and speakers like...
Does it have 6x speakers - I know some STi's have 6.
Is the stereo naff?
Postby Azyman » Thu Jun 11, 2009 9:04 pm
naff is the word :D
Regs
Azyman
Postby MaverickUK82 » Thu Jun 11, 2009 9:08 pm
it does look kind of ugly... double din units are rather limited and costly... does it sound ok?
what are are the speakers like?
Postby danr55 » Thu Jun 11, 2009 9:24 pm
MaverickUK82 wrote:it does look kind of ugly... double din units are rather limited and costly... does it sound ok?
pants, pants, pants, pants and pants
Hope this helps :thumb:
Postby MaverickUK82 » Thu Jun 11, 2009 9:30 pm
so the speakers and head unit are going to have to be replaced before I change anything when I eventually get one...?
are there 6x speakers or 4x...
Do you know what size they are?
Postby WR1 Bro » Thu Jun 11, 2009 11:09 pm
about this big
Postby WR 1mposter » Thu Jun 11, 2009 11:31 pm
Stereo is worth £2 speakers are free ! sums it up !
Fitted a alpine unit with genesis speakers, amp, an dynamat the doors, only done the front, cos I dont sit in the back an no one else does either :lol:
Postby MaverickUK82 » Fri Jun 12, 2009 7:19 am
is dynamat sound deadening? Is it heavy and how about fitting? is it hard to fit it all...?
Postby WR1 Bro » Fri Jun 12, 2009 7:27 am
MaverickUK82 wrote:is dynamat sound deadening? Is it heavy and how about fitting? is it hard to fit it all...?
Yes, that is exactly what it is. I believe you can get some ligther dynamat which is more expensive.
Fitting depends on you. My limit is a spot of oil and lots of petrol. Therefore, I would not begin to change a stereo. Having seen others do it I guess it is fairly easy with the right tools. Since I own a hammer and a spade I'm not really set-up for the job.
Postby CAVEMAN » Fri Jun 12, 2009 9:04 am
dynamat is pretty much a thin layer of tar stuck onto the back of self adhesive pads.
Does an awesome job of reducing any vibrations. I put it on my projector mounts to stop any unwanted building vibrations disturbing the image.
To get it into awkward places you can use a heat gun to warm it up and bend it better. A good sharp knife is always handy too.
Postby MaverickUK82 » Fri Jun 12, 2009 9:23 am
is there a disadvanage of having it?
where do you ahve to stick it? all panels? Or ones that are likely to vibrate? will it weight you car down loads...?
Postby CAVEMAN » Fri Jun 12, 2009 9:57 am
There is always a downside to somethings!
By adding the dynamat, you help reduce these panel vibrations.
You can stick it where you like, but most people put it on the door skin and in and around the speakers.
You can always take away the factory sound deadening stuff to re-distribute the extra weight. Lots under carpet and behind rear seats. This will all add extra kilo's.
Postby p060064h » Fri Jun 12, 2009 1:11 pm
Amp head unit front & rear speakers the lot, it cost £1700 to fit but i dont need it any more if your interested.
p060064h
Postby MaverickUK82 » Fri Jun 12, 2009 8:26 pm
Wow man. I thought I was an audiophile. What's the setup?
Postby WR 1mposter » Fri Jun 12, 2009 9:38 pm
As Caveman says sharp knife heat gun, plus a 1" roller as well so as you lay it you roll it to remove any air bubbles and give it a good adhesion to, got the liteweight stuff fitted, inside of the door is covered along with the door card and around the speakers....only downside is you really cover every bit you can and the electric window or door handle are needed to be got at it is a bastird :lol:
Postby Megaman » Fri Jun 12, 2009 9:45 pm
I got a pioneer dvd/mp3/sat nav double din head unit to replace default one for around 700-800 notes... then changed all four speakers for better ones... however the newer ones are only a fraction better than standard and if i was to do it again id spend a lot more than 200-300 on speakers... i also have dynamat in the doors which helped a lot...
I made the mistake of listening to the local subaru garage who told me they had an audio genius who fits all their stereos who would sort me out. I didnt give the guy a budget just said i want the best quality and loudness speakers i can get in the WR1 that will fit.. i do seem to remember a lot of people advising me that subaru doors are very thin so choice of speaker is limited unless u carve away the door or something..
Postby Crockel » Sat Jun 13, 2009 9:07 am
Has anyone got any photos of the stereos they have installed? I am looking to change the standard unit as well as trying to get an idea for alternatives and something that fits with the look of the interior.
Lee
Crockel
Postby CAVEMAN » Sat Jun 13, 2009 9:45 am
I would go for any touch screen double DIN head unit, Kenwood, Alpine, Pioneer etc...
Or you can get a in car PC with touchscreen. Hide all the PC gubbins away and get XP on your touchscreen. Then add a USB GPS sensor and wifi for a complete in car entertainment system.
Postby Gee Wr1 » Sat Jun 13, 2009 9:55 am
Megaman wrote: i do seem to remember a lot of people advising me that subaru doors are very thin so choice of speaker is limited unless u carve away the door or something..
There is a not much depth for fitting speakers so you have to make up MDF spacer rings to allow you to fit speakers with deeper magnets NOT HACK AWAY AT THE DOOR :shock:
There are plenty of sites with the pattern for making the mdf spacer rings like scoobynet. You can also use corsa spacer rings from the likes of halfords they fit to.
Postby Megaman » Sat Jun 13, 2009 11:20 am
Like i said before mate our local garage put me in touch with a proper diamond geezer who clearly knew his stuff :roll:
:lol:
