turbo hoses
![Post Post](./styles/AeroBlue/imageset/icon_post_target.gif)
Sun May 10, 2009 4:06 pm
by ROSSCO
when my turbo kicks in, there is an air movement noise, it almost sounds like something is leaking ( a hose or something) Are there any hose prone to coming off or leaking ?
Thanks
Sun May 10, 2009 4:10 pm
by The Swede
Depends how loud it is. But if it already makes noise now, it would mean it's already leaking so you will not have the normal performance.
(Moved the topic also to its correct area on the forum, ROSSCO.)
Sun May 10, 2009 4:34 pm
by ROSSCO
It still boosts fine, i have checked all the obvious hoses, i think.
Sun May 10, 2009 7:50 pm
by WR 1mposter
Once hoses have been removed, unless cleaned properly with a solvent based cleaner to remove old oil residue they will come off, marky mark used hairspay once they are cleaned an ready to put back on...makes em stick apprently
![Confused :?](./images/smilies/icon_confused.gif)
Sun May 10, 2009 8:33 pm
by Gee Wr1
Yep using hair spray to seal hoses works a treat.
Are you sure its not like a whistling fluttering noise you are hearing? Mine has always made that sort of noise when the turbo starts spooling since day 1 5years ago.
Sun May 10, 2009 8:37 pm
by ROSSCO
it does sound like a whistling noise when the turbo spools up . Maybe i dont have a problem. thanks
![WooHoo happy :woohoo:](./images/smilies/WooHooHoo.gif)
