Camber set up on wr1Can anyone help my front tryes are wearing on the insides and have been to it could be the camber or it might just be the tracking
Just want to get it sorted before I put the new p zeros on escort rs 2000
Find somewhere that does the 4wheel laser alignment in your area & get them to set the camber & tracking for you. Get the car booked in for that then get the new tires fitted just before you go, if you get it set up on worn tires then put new ones on it'll be slightly out.
Just had my 4 wheel alignment done up at Revolution in Newcastle.
Same reason as you, was getting four new wheels and tyres fitted. I'll dig out report and scan it as a pdf for you as the settings are on there. I had to get camber bolts fitted to rear as they did not have them on the car - is this right ???
Sound I'm from the south Yorkshire
Area anyone no were I can get it done and how Much will travel but not silly miles escort rs 2000
Yes normal price they charge is £100 + vat but we got a special offer on TTS so they did it for £50 + vat.
Keep an eye out on some of the local scoob sites.
I just had mine done recently, cost me £75 + VAT for four wheel alignment and 1.5 hours labour for adjustments. All in £172, so 50 + VAT very cheap!
Time to get mine sorted me thinks, althogh it feels alright but doen't hurt to have it checked
Were tho thanks the thing near south Yorkshire HELP
escort rs 2000
When getting your alignment done be sure to mention it's not the same settings as the standard sti, which most independant garages will set it too, the lowering springs fitted to the 1 make a difference !
Yes so were can they get the wr1 camber settings from then
As I need em having it done Friday escort rs 2000
forum/viewtopic.php?p=9297#9297 :
"The settings are Front camber -1 degree 15 minutes Front toe 6 minutes in Rear toe 10 minutes in These are the std settings for the road and should be how the car was set when the springs were changed. It is worth getting your dealer to check them though. Mike"
More camber needed and get rid of that toe in
Duncan : www.racedynamix.com
Re: Camber set up on wr1
This will be because of the front wheels are toeing out. Set to 1.5 deg neg camber front and zero toe all round to bring it alive Duncan : www.racedynamix.com
is this same as the factory wr1 settings or different
escort rs 2000
Different.
factory settings have such a wide variance and most alignment centre would be happy with 0.6 deg difference - quiet scarey how much difference this makes to the handling. Stand with them to make sure they do it precisely. Duncan : www.racedynamix.com
How will this bring the car alive does it make that much
Difference to the handling.how is this setting different to the factory escort rs 2000
Why zero toe at the front too? With how awefully understeered the scoob is, I'd have expected you didn't want to bring the front 'alive'. How much camber do you give the rear ?
There is a real mixed bag of opinions on the toe settings needed. Some say toe out brings it most to life, some say toe in makes it more stable. Zero toe is a middle ground and doesnt waste any forward motion in tyre scrub.
The natural inclination of the bushes flexing brings toe out on braking and initial turn in but transitions to toe in on application of power. My camber settings are a little more extreme than what you would want to run on the road. I have -3 degrees at front and -2 degrees at rear. Duncan : www.racedynamix.com
Interesting. I used to want to have a lively rear (less camber than the front, no toe in) until I discovered that the Evo is damn tail happy compared to the scoob . Running same camber front and rear and 1mm of toe in at the rear at the moment. It fits my driving style reasonable as I tend to be reasonable 'brutal' when turning in. Not as good as a set-up as what the Finns used to set up the car as though.
Toe in at the rear calms the tail-happy behavior down - sounds like good settings you have
