defi gauge oil temp sensor, where should it be ?
Postby ROSSCO » Sat Apr 25, 2009 7:52 am
What is the location of the defi gauge oil temp sensor ?
Thanks
ROSSCO
Postby Gee Wr1 » Sat Apr 25, 2009 5:40 pm
Most common take of for oil temp sensor is a sandwich plate that fits in between the oil filter & sump but its not the most accurate place to get a reading from.
Postby WAYNE WRX » Sun Apr 26, 2009 2:01 pm
Theres a location on top of piston number3, if I remember correctly, its and allen key fitting, remove that and you need a brass adaptor to put your sender into, when I get chance Ill post the place up to get the adaptor, even seen them on ebay sometime 8) 8) 8)
WAYNE WRX
Postby rocko » Sun Apr 26, 2009 5:24 pm
Well mines under the intercooler inlet hose, you need to take out a bung with allen key then fit another bung which allows you too fit defis sensor
I would say this is most common .. you can get an block adaptor from RCM but only allows you to fit standard water temp and oil presure .. if you try and fit defi oil temp the sensors touch inside.. !!
rocko
Postby WR 1mposter » Sun Apr 26, 2009 6:04 pm
Gee Wr1 wrote:Most common take of for oil temp sensor is a sandwich plate that fits in between the oil filter & sump but its not the most accurate place to get a reading from.
Mines fitted with the sandwich plate, as far as i'm aware over the few track day we have been to along with other members from here we are running at the same temp, although they may have in the same place, or they may not :lol:
Postby WAYNE WRX » Sun Apr 26, 2009 9:59 pm
rocko wrote:Well mines under the intercooler inlet hose, you need to take out a bung with allen key then fit another bung which allows you too fit defis sensor
Thats where I meant 8) 8) 8) 8) 8) 8)
WAYNE WRX
Postby ROSSCO » Sun May 10, 2009 8:39 pm
any pictures please
ROSSCO
Postby WUZ » Fri Jun 26, 2009 7:15 pm
Running it above Cyl#3 is the preferred option as you wan tto see the MAX temp you oil has to endure...................... sandwich plate above the Oil Filter WILL NOT GIVE YOU THIS.
Mineral Oils Degrade about 110-115 but you can get that with Track driving but with a Temp Sensorin the Sandwich plate - you'll never know.
Adaptor for #3 is LMA067 - cost about 6-7UKP delivered to your house
:D
Russell
WUZ
Postby ROSSCO » Sat Jun 27, 2009 10:59 am
Mine is in the sump plug and reads a 110-115 when in traffic.
ROSSCO
Postby WUZ » Sat Jun 27, 2009 7:06 pm
ROSSCO wrote:Mine is in the sump plug and reads a 110-115 when in traffic.
Defi Sensor? Degrees Celcuis?
If your not running it already, run a FULLY ester based Synthetic ASAP (Silkolene Pro S or Motul 300V) coz your Oil going past #3 and round Turbo will be a LOT higher than that!
WUZ
