Does anybody know what the pcd of the WR1 is im unsure if its 5x100 or 5x114
Your help would be grately apreciated
thanks
PCD of the WR1Does anybody know what the pcd of the WR1 is im unsure if its 5x100 or 5x114
Your help would be grately apreciated thanks Sooty,
Needs a WR1 now his WRX300 is sold Or a spec D
Re: PCD of the WR1
silly question whats pcd Regs
Pitch Circle Diameter
I.e 5 X 100 means it has 5 holes, equi-distantly spaced, drilled on an effective diameter of 100mm. 360/5 = 72, so in this case there are 5 holes, 72 degrees apart, drilled on a 100mm diameter circle. If JP is Roland Rat, them I am Errol the Hamster... His number 1 fan.
Who is onlineUsers browsing this forum: No registered users and 9 guests |
