by JP » Thu Nov 09, 2006 8:55 pm
stijoy wrote:dont worry mate, this lot on here twist everything
more liked these lot r twisted....
JP
by stijoy » Thu Nov 09, 2006 9:00 pm
JP WR1 wrote:stijoy wrote:dont worry mate, this lot on here twist everything
u have hit the nail on the head there mate
stijoy
- Moderator
by SPIKE LIKE MIKE » Thu Nov 09, 2006 9:24 pm
and the other half are "bent "
- "Special Needs" constable
by WR 1mposter » Fri Nov 10, 2006 12:01 am
WR1 Bro wrote:JP WR1 wrote:WR1 Bro wrote:I will check this information out with my mate Pasty. He has shown you to talk bollocks on a couple of occasions recently.
Can someone pls tell me who is Pasty?
Pasty is the bloke you don't like.
WTF have i done to upset JP..... I suppose its my fault now, that he vanished for a few weeks
by WR 1mposter » Fri Nov 10, 2006 12:14 am
marky mark wrote:I am not sure if thats a good thing or not Bro. The only thing stopping me snipping your brake pipes would be the thought of your lovely wife and beautiful son. Most people who put them in sandwich plates, rather conveniently also supply the sandwich plates as well
My oil temp and pressure are attached to the sandwhich plate, but I did'nt buy the defi's from the people I got the S/P from ! I may be mistaken but do not "defi" also do a S/P and do they not also recommend using it !...... Why if it's going to give a false reading ! Which inturn would not be good for the so called being the most accurate/best gauges you can buy ! I not saying your wrong Mark...more than likely your right But these so called companies that spend thousands on development, to be better than there rivals, but then develop something that does not do what it says on the tin
by WR 1mposter » Fri Nov 10, 2006 12:17 am
marky mark wrote:Oh well, sounds like they did a great job. wired up wrong and 2 out of the 3 sensors wrong.
The critical part (as far as oil temps are concerned) is at the big ends. Putting the temp sensor either in a sandwich plate or even worse the sump plug is not fantastic. they are exposed to the wind a little etc and measure the oil where its at its coolest.
In the main gallery you will measure pretty much what the crank/big ends see.
Think of it the same as putting your water temp sensor in the radiator. stupid idea. thats why the water temp sensor on a scoob is in the crossover pipe under the inlet manifold on the top of the engine - so it sees exactly what the engine is seeing temp wise.
Putting the boost sensor directly into the inlet manifold is fine.
Next time i'm passing you way can you refit mine As you know fitted myself, buy still have not tided up the sensor wires I pay you in beer.....few pints should do ain't that right Bro
by marky mark » Fri Nov 10, 2006 6:55 am
Sorry Martin, Its well known - not to mention fairly obvious engineering principle - that it shoud measure at the place where the oil is hottest. The pump and filter area is next in the oil feed system from the sump. The sump is thin steel hanging out in the air a bit (deliberately to aid cooling) so its impossible to argue that measuring it there is correct. It wont be a million miles off for sure (it's unquantifiable) Measuring from the main gallery, where the oil is subject to heat soak through the cases etc, and closest to the pistons and crank - where the oil is actually doing a job - is the way to go. The oil in the sump/filter area is doing nothing lubrication wise, why would you want to measure it there? I dont know if Defi sell sandwich plates TBH. They are useful for fiting an oil cooler etc. And as i have said before any manufacturer will sell anything if there is enough people to buy. The adaptor to fit it into the gallery is 5 or 10 quid, a sandwich plate is a lot more. Without wishing to pi$$ on your fire or make me sound even more up myself than i actually am , I am heavily involved in the design of performance engines. This stuff is not subaru related, its just simple engineering practice.
- JPs little helper
by marky mark » Fri Nov 10, 2006 7:41 am
Thinking about it even more, you may have noticed that you attach your sandwich plate directly to the modine. The modine provides oil cooling via the water system to which it is directly attached too, just downstream of the radiator in the loop. So the coolest water in the whole sytem is used to try and keep a curb on the oil temps, right at the point where you are measuring. Oil modine is shown in this pics of my engine. Its the bronze thing that the filter screws into with the pipes going across to the water pump.
- JPs little helper
by WR1 Bro » Fri Nov 10, 2006 8:23 am
Anymore pics... I've never seen an engine other than from the top!
- Site Admin
by marky mark » Fri Nov 10, 2006 8:28 am
Feck me yes i have loads. Have you not seen my project thread on P1woc? 40 odd pages detailing rebuild and loads of internal pics etc.
- JPs little helper
by marky mark » Fri Nov 10, 2006 8:34 am
My run around while car was off road!
- JPs little helper
by WR1 Bro » Fri Nov 10, 2006 8:35 am
marky mark wrote:Feck me yes i have loads. Have you not seen my project thread on P1woc? 40 odd pages detailing rebuild and loads of internal pics etc.
LINK
- Site Admin
by WR1 Bro » Fri Nov 10, 2006 8:37 am
Do those carbon effect headlight trims come as standard... or is that your Chav addition?
- Site Admin
by WR1 Bro » Fri Nov 10, 2006 8:38 am
marky mark wrote:
I can't comment on cars like this as I wouldn't been seen dead near one. You must have looked special!
- Site Admin
by WR1 Bro » Fri Nov 10, 2006 9:14 am
stijoy wrote:at least you can fit in there mark, unlike a few on here
You are really trying to set yourself up for a beasting at Xmas party. Bring it on!
- Site Admin
by stijoy » Fri Nov 10, 2006 9:17 am
WR1 Bro wrote:stijoy wrote:at least you can fit in there mark, unlike a few on here
and do you think i could get in there stu and as the comment stated A FEW
stijoy
- Moderator
by WR1 Bro » Fri Nov 10, 2006 9:20 am
No need to explain Pops... You comment was SIMPLE and clear, as per usual!
- Site Admin
by marky mark » Fri Nov 10, 2006 10:06 am
I admit the headlamp protectors are not pukka. I could not find any plain ones. Heres the link Bro, its a long read im afraid! http://p1woc.co.uk/postnuke/index.php?n ... pic&t=7364
- JPs little helper
by The Swede » Fri Nov 10, 2006 10:37 am
marky mark wrote:Heres a pic i am sure you will comment on Bro!
Brilliant pic, Mark ! Talking about a car with 1 brake donkey power !
- Moderator
by WR1 Bro » Fri Nov 10, 2006 10:43 am
Torrekens wrote:marky mark wrote:Heres a pic i am sure you will comment on Bro!
SO true....
- Site Admin
by marky mark » Fri Nov 10, 2006 10:49 am
It was taking and posted without my knowledge by my Mischevious wife who found the whole thing very amusing
- JPs little helper
by WR1 Bro » Fri Nov 10, 2006 10:56 am
marky mark wrote:It was taking and posted without my knowledge by my Mischevious wife who found the whole thing very amusing
Seems we know who got all the personality in that relationship!!
- Site Admin
by JP » Fri Nov 10, 2006 12:44 pm
WR 1mpostor (aka number 1 moderator) wrote:WR1 Bro wrote:JP WR1 wrote:WR1 Bro wrote:I will check this information out with my mate Pasty. He has shown you to talk bollocks on a couple of occasions recently.
JP
by SPIKE LIKE MIKE » Fri Nov 10, 2006 5:17 pm
[quote="WR1 Bro"] I gay gimp power transverse engine!!
by WR 1mposter » Sun Nov 12, 2006 2:12 am
marky mark wrote:Sorry Martin, Its well known - not to mention fairly obvious engineering principle - that it shoud measure at the place where the oil is hottest. The pump and filter area is next in the oil feed system from the sump. The sump is thin steel hanging out in the air a bit (deliberately to aid cooling) so its impossible to argue that measuring it there is correct. It wont be a million miles off for sure (it's unquantifiable) Measuring from the main gallery, where the oil is subject to heat soak through the cases etc, and closest to the pistons and crank - where the oil is actually doing a job - is the way to go. The oil in the sump/filter area is doing nothing lubrication wise, why would you want to measure it there? I dont know if Defi sell sandwich plates TBH. They are useful for fiting an oil cooler etc. And as i have said before any manufacturer will sell anything if there is enough people to buy. The adaptor to fit it into the gallery is 5 or 10 quid, a sandwich plate is a lot more. Without wishing to pi$$ on your fire or make me sound even more up myself than i actually am , I am heavily involved in the design of performance engines. This stuff is not subaru related, its just simple engineering practice.
Not being one to make you sound even more up your arse than you already are I take most seriously on what you have to say and believe your techy ability is way above mine and most on here But like most on here we do buy with out techy knowledge and questioning your superior techy knowledge, without doubt will prevent some poor unsuspecting ass like jp buying something in the future, that is not required So hope you dont mind me questioning you,and sometimes stating the obvious to make you explain things more so than we know !
by WR 1mposter » Sun Nov 12, 2006 2:13 am
JP WR1 wrote:WR 1mpostor (aka number 1 moderator) wrote:WR1 Bro wrote:JP WR1 wrote:WR1 Bro wrote:I will check this information out with my mate Pasty. He has shown you to talk bollocks on a couple of occasions recently.
This is for you JP your only worth the one
