![Post Post](./styles/AeroBlue/imageset/icon_post_target.gif)
I suppose an ECU is only as good as it is mapped i.e. mapper's ability. If the mapping is not quite up to scratch then you may not be fully utilising the ECUs potential? ![Confused :?](./images/smilies/icon_confused.gif)
JP wrote:I suppose an ECU is only as good as it is mapped i.e. mapper's ability. If the mapping is not quite up to scratch then you may not be fully utilising the ECUs potential?
JP wrote:I still have the std ECU which was mapped to 360 brake. I guess the only advantage the Solaris has is things like anti lag and launch control and a mode switch where I can switch for the car to run 97 ron i.e. inferior petrol in case of emerencies, then switch back when I have V Power. However, that said, I have been experiencing spookythings like the AC not working, lights going out on the heater switches etc. Not sure what will be next
I will see what Paul says at Zen when I am down there in 2 weeks - he seemed very positive when I told him I was running a Solaris ECU. I guess I shoud stick to Solaris for now and give Paul the opportunity to work his magic.
danr55 wrote:any problems with horn/hazards? I have had the light for heater controls go 3 times since the rebuild, and horn and hazards more than that, replace the fuses and they dont last long. seems to be a short somewhere on the horn which will be investigated next time the car is in, I know Dunc has similar probs...
JP wrote:danr55 wrote:any problems with horn/hazards? I have had the light for heater controls go 3 times since the rebuild, and horn and hazards more than that, replace the fuses and they dont last long. seems to be a short somewhere on the horn which will be investigated next time the car is in, I know Dunc has similar probs...
Now that is interesting Dan. In the 2 years of my ownership of the "1" before the mods, I never experienced anything going wrong inside the car. Since the mods it's been
Lights - on the heater dial has gone.
A/C - does not work
Heat - you have to turn it right to maxfor heat otherwise it blows cool air
but not cold enough to replace the A/C
I hope the horn does not go as I have been using that extensively since starting my new job travelling to Theale everday!
marky mark wrote:JP wrote:danr55 wrote:any problems with horn/hazards? I have had the light for heater controls go 3 times since the rebuild, and horn and hazards more than that, replace the fuses and they dont last long. seems to be a short somewhere on the horn which will be investigated next time the car is in, I know Dunc has similar probs...
A/C - does not work
Thats what you get from taking your car to Scoobyclinic. Ask WR1 Bro what's gone wrong with his since he had it messed with ....![]()
The heater and air con thing - You could well have an air lock in the coolant system up in the heater matrix area. I would drain and refill the system.
JP wrote:Thank you!![]()
Marky Mark - Don't remind me of Scooby Clinic - what a headache that was!
WR1 Bro wrote:JP wrote:Thank you!![]()
I'm sure "they" have a side to this story too and life experience tends to suggest it will not be one sided. Given your history I would put a huge bet on thisI just hope you don't bring a "bad" name to WR1s with RCM.
JP wrote:WR1 Bro wrote:JP wrote:Thank you!![]()
When you have spent over £6.5k then you have some rights as a customer to complain considering it took them 3 go's to get it right - and even then they were not able to come up with the figures I was sold in the first place! You need not worry about RCM as Paul at Zen is able to provide mapping for the solaris - I am sure you will not loose your group discount at RCM!
jd wrote:JP in lala land again?
WR1 Bro wrote:JP wrote:WR1 Bro wrote:JP wrote:Thank you!![]()
Group discount???
