by spraggol » Tue Apr 20, 2010 9:23 pm
Just had new performance friction pads fitted all round and they make quite a loud 'clonky' type of noise every time I press the brake pedal at low speeds
I went back to the garage who fitted the pads and showed them the problem and they told me theres nothing wrong with them and said its simply the nature of the pads as they 'float' in the calipers. They said its probably made that noise from day one but is more noticeable now with the new pads because the fast road pads are much harder therefore make a stronger/louder noise.
Can anyone else shed any light on the matter.
Ive done about 400 miles on the new pads now so there definitely worn in!
Cheers guys
WR1 no. 427
spraggol
by John Mc » Wed Apr 21, 2010 6:40 am
Somebody posted a fix to this by Alyn at ASP?!? Wasn't it something like thicker grease or something??
by WR1 Bro » Wed Apr 21, 2010 7:02 am
It was a post by Alyn. He said where to put the copper grease. I know you usually put copper grease on the rear of the pad but I think he mentioned on the edges too... Search for the post and don't trust my memory.
- Site Admin
by dano17439 » Wed Apr 21, 2010 8:44 am
I have PF pads and have the exact same problem. Only happens at under 10mph though. Be interesting to see the fix
dano17439
by John Mc » Wed Apr 21, 2010 11:46 am
by WR 1mposter » Wed Apr 21, 2010 5:49 pm
WR1 Bro wrote:It was a post by Alyn. He said where to put the copper grease. I know you usually put copper grease on the rear of the pad but I think he mentioned on the edges too... Search for the post and don't trust my memory.
Does'nt copper grease melt under heat !
by John Mc » Wed Apr 21, 2010 8:54 pm
WR 1mpostor (aka number 1 moderator) wrote:WR1 Bro wrote:It was a post by Alyn. He said where to put the copper grease. I know you usually put copper grease on the rear of the pad but I think he mentioned on the edges too... Search for the post and don't trust my memory.
I think it is some other grease reading the thread....
by spraggol » Thu Apr 22, 2010 1:52 pm
Whats this 'red' grease called?
WR1 no. 427
spraggol
by John Mc » Thu Apr 22, 2010 5:42 pm
spraggol wrote:Whats this 'red' grease called?
give Alyn at ASP a ring... then you can confirm it on here for future reference?
by Chris 280 » Thu Apr 22, 2010 8:00 pm
got p.f pads on mine done at autotecnica, no noise on it though.
Chris 280
by John Mc » Fri Apr 23, 2010 6:20 am
280 wrote:got p.f pads on mine done at autotecnica, no noise on it though.
Adam probably used some of his white stuff on it
by WR1 Bro » Fri Apr 23, 2010 7:16 am
John Mc Tiddler (Dogging Expert) wrote:280 wrote:got p.f pads on mine done at autotecnica, no noise on it though.
He uses white stuff on other things... not on brakes.
- Site Admin
by spraggol » Thu Jun 17, 2010 1:54 pm
Tried everything and nothing seems to cure it. Last option would be to change pads AGAIN. Do redstuff pads suffer the same problem?
WR1 no. 427
spraggol
by asperformance » Thu Jun 17, 2010 4:35 pm
copper grease doesn't melt in brake systems (unless your running "le mans" type laps!!)
out of all the cars we see its usually a combination of pad debris build up inside the pad guides of the caliper (simple cleanliness when fitting new pads) and a lack of copper grease in the correct place..........
