front fog light switch wantedfront fog light switch wanted
Re: front fog light switch wanted
83001FE000 Switch-Driving Lamp SACC6040 Decal-Driving Lamp Switch Part numbers for fog light light switch and sticker which converts the switch into a driving light switch, note the switch wont light up due to the sticker. Avalilable from your local dealer. Ant,
I reckon ANT has all the part numbers for everything implanted in his brain
Guys you might find this usefull, I managed to get a copy of the bulletin that lists all the WR1 bits so have copyed it in below.
Please find below the Part Numbers of the WR1 UK fit items. Part Number, Description, Note, SACC2580 Alloy Wheel 18" P-FF7 Pewter SACC2555 Spring Kit SACC2555A Bump Stops SACC2568 Mesh Grille Set Upper & Lower SACC2569 PIAA Driving Lamp Kit SACC2569L PIAA Replacement Lens & Body 82501FC100 Relay-Driving Lamp 83001FE000 Switch-Driving Lamp 84927FE1W Bracket-Driving Lamp RH 84927FE114 Bracket-Driving Lamp LH H4518FE050PN Driving Lamp Sunounds Supplied as a pair SACC6040 Decal-Driving Lamp Switch 53000306 Bulb Filter-Switch J5010SE410UK Carpet Mat Set SACC6041 Label-Tyre Pressure SACC3453 / SACC3454 Decal-Front Wing (R/H 53, L/H 54) SACC2582 Gear knob *No Part Number, Tax Disc Holder Uniquely Numbered* *No Part Number, Centre Console Insert No LongerAvailable* *No Part Number, Key Ring No Longer Available* *No Part Number, WR1 Warranty & Service Book No LongerAvailable* * Only 500 pcs of these items were produced. No replacement items are available. Ant,
Who is onlineUsers browsing this forum: No registered users and 27 guests |
