PIAA Windscreen Wipers
What are you after?
Postby WR1 Bro » Fri May 12, 2006 1:06 pm
I need some PIAA wipers. Where is the best place to order them from?
Are these sizes correct:-
22inch Drivers side
17inch Passengers side
Postby jd » Fri May 12, 2006 1:08 pm
Halfrauds?
1mposter is my hero.
jd
Postby marky mark » Fri May 12, 2006 1:16 pm
I have these and they are superb!!!!!
I got them from GGR but since realised i was paying over the odds. this was the best place i found for them. will also give you the sizes (in case they are different to your car)
Are you capable of a DIY fitment? :rofl:
http://www.speeding.co.uk/acatalog/Piaa ... lades.html
Re: PIAA Windscreen Wipers
Postby The Swede » Fri May 12, 2006 1:17 pm
WR1 Bro wrote:I need some PIAA wipers. Where is the best place to order them from?
22inch Drivers side
If you wait for 3 months, you can have mine for free
The 'housing' is pretty expensive, but you can replace the rubbers in them pretty cheaply.
Got the carbon look ones.
Postby WR1 Bro » Fri May 12, 2006 1:25 pm
22inch Drivers side
Cheers Mate. You are a love.
Postby jd » Fri May 12, 2006 1:29 pm
:gay: :hump:
jd
Postby WR1 Bro » Fri May 12, 2006 1:37 pm
jd wrote::gay: :hump:
Off thread. Serious post.
Postby jd » Fri May 12, 2006 1:38 pm
Makes a change.
jd
Postby marky mark » Fri May 12, 2006 1:40 pm
Makes a change for him to post!
who gives a fook where it is? its pretty much the same tripe as before his little sabbatical! PMSL.
Postby jd » Fri May 12, 2006 1:42 pm
:toofunny:
sabbatical or temper tantrum, answers on a postcard to.......
jd
Postby stijoy » Fri May 12, 2006 5:40 pm
got mine from scoobyworld, think it was 21 and a 19 inch wipers.
stijoy
Postby The Swede » Fri May 12, 2006 6:38 pm
stijoy wrote:got mine from scoobyworld, think it was 21 and a 19 inch wipers.
No clue which size, but pretty sure the WR1 wipers are still the same as the STi ones.
I'll keep mine for Bro. You probably only need other blades.
Cheerio
S.
Postby stijoy » Fri May 12, 2006 6:39 pm
hold on just going outside to measure them :wink:
stijoy
Postby stijoy » Fri May 12, 2006 6:44 pm
just been out but forgot i have put my original ones back on as the piaa ones dont like the salt :cry: but the original ones are 22 and 17.
stijoy
Postby marky mark » Fri May 12, 2006 6:56 pm
Hang on a sec here - how can you use second hand ones? for them to work properly you need to treat the windscreen first so where you going to get that from???
Postby stijoy » Fri May 12, 2006 7:03 pm
the wipes i got to prepare the screen, i got 2 in each of the wiper boxes :lol:
stijoy
Postby The Swede » Fri May 12, 2006 7:45 pm
Not sure that treating windscreeen really does anything. If you think of it, you're just nicely cleaning it and two weeks later, the thing is saturated with polluted particles again.
Still, I must say I am very pleased with the PIAA wipers, which had been recommended to me by Pops, btw. :thumb:
I have used them throughout the winter here, including in April and october, the two months when they use salt on the roads (abundantly !).
No decrease in their performance.
Build quality is also spot on.
Expensive ? Yes ! Worth it ? Yes !
Postby osaka » Thu Jun 14, 2007 1:07 pm
we have them on sale -
check out our ebay shop: link os found on our site:
www.osaka-autodesign.com
osaka
Postby WR1 Bro » Thu Jun 14, 2007 1:29 pm
osaka wrote:we have them on sale -
I can't find the link to your ebay shop.
Postby WR1 Bro » Thu Jun 14, 2007 1:31 pm
Found it... I can't find the sale prices though?
Postby osaka » Thu Jun 14, 2007 1:33 pm
osaka
Postby Robocop » Thu Jun 14, 2007 6:41 pm
My I suggest Bosch Aerotwins as replacements. I changed from PIAA to these and found several improvements.
Chris B and Bob also have them fitted.
Here's a few shots I've just taken.
Available from your local dealer for
Robocop
Postby stijoy » Thu Jun 14, 2007 7:05 pm
they beat the piaa in my opinion
stijoy
Postby WR1 Bro » Thu Jun 14, 2007 7:11 pm
Can someone explain why you rate them so highly? Very interested to hear the benefits they offer over the PIAAs.
Postby Robocop » Thu Jun 14, 2007 7:23 pm
Robocop
Postby stijoy » Thu Jun 14, 2007 7:29 pm
having tried both, these new ones are better 8)
give them a try stu :wink:
stijoy
Postby Robocop » Thu Jun 14, 2007 7:34 pm
I first saw them on some Merc C Classes we had. They're standard fit now on Merc VW Audi and a fair few others.
To start with you could only buy them to fit the ones that came OE, but now they're starting to filter through as direct replacements for non OE.
They sit much lower on your windscreen as my last picture hopefully shows. Standard blades have about 8 pressure points where the rubber is pressed against the screen. With the "Flat blades" as they've been called, it's over 1000 contact points.
Robocop
Postby danr55 » Thu Jun 14, 2007 9:40 pm
i have these bosch things too apprently, they seem to work well, slightly less well since some twat bent the sh1t out them :evil:
Postby WR1 Bro » Fri Jun 15, 2007 7:42 am
How do they compare when you don't want to use the wipers at speed since the PIAA leave behind a quick clear silicone film?
Postby marky mark » Fri Jun 15, 2007 7:48 am
This is what i like about the Piaa's, the fact that you hardly have to use them at 60mph+
Next
Return to Wanted
