front 02 sensor
What are you after?
front 02 sensor
Postby WR1 WOZA » Fri Mar 19, 2010 10:59 am
Looking for a front 02 sensor for a Wr1/Sti 04 ! must be in good working order/ Newish number : code on it is 22641AA042
WR1 WOZA
Postby Autotecnica » Fri Mar 19, 2010 1:52 pm
try grade-a-subaru, 01663 744114 8)
Autotecnica
Re: front 02 sensor
Postby buffy » Fri Mar 19, 2010 7:28 pm
have you tried the dealer near you whos breaking a wr1 ????
LBUFFIN
buffy
Re: front 02 sensor
Postby Azyman » Fri Mar 19, 2010 7:43 pm
WR1 WOZA wrote:Looking for a front 02 sensor for a Wr1/Sti 04 ! must be in good working order/ Newish number : code on it is 22641AA042
your having a night mare at the moment mate :(
hope you get it sorted :)
Regs
Azyman
Postby adiboy » Fri Mar 19, 2010 8:59 pm
sorry im no help but was wondering why you need one, what simptoms have you got as mine is running rich and hunts on idle bad. thanks
adi
adiboy
Postby WR1 WOZA » Fri Mar 19, 2010 10:11 pm
Ye im waiting to hear from the chap local breaking a Wr1 been a week so getting fed up thought id ask elsewhere ! The reason i believe its the the sensor as engine light stays on and throws up code p0138 ! reset a couple of times but keeps coming back ! This is what ive looked up and found on this site
http://www.obd-codes.com/trouble_codes/
A code P0138 may mean that one or more of the following has happened:
Faulty O2 sensor
Short to battery voltage in O2 sensor signal circuit
High fuel pressure (not as likely) :cry:
WR1 WOZA
Return to Wanted
