HARVEY SMITH trick uppipes & ported headers
Postby asperformance » Sun Feb 24, 2013 8:27 pm
Cementing a long established association with the various companies previously involved with manufacturing the intensively developed Harvey Performance “trick” up-pipes and ported headers for the Subaru tuning scene, AS Performance has established the exclusive rights to continue their supply.
As a tribute to their creator Harvey Smith, who sadly passed away in late 2012, they will continue to be called the “Harvey” up-pipe
available in std fitment and 2bolt & 3bolt GT Spec style for improved spool and responce
STOP PRESS – HARVEY trick up-pipes manufacture | AS Performance
https://www.facebook.com/media/set/?set=a.553517494659990.127795.451552721523135&type=3
Re: HARVEY SMITH trick uppipes & ported headers
Postby asperformance » Sun Jan 19, 2014 4:34 pm
slightly updated pricing
std 2bolt fitment "trick" up-pipes are £157.50inc./fully DEI heat wrapped and with 5x new studs and delivered to std UK postcodes
2 bolt and 3 bolt "GT Spec, RCM, Lateral, etc." type fitments also available at £165inc./fully DEI heat wrapped and with 5x new studs and delivered to std UK postcodes
we are the only manufacturer/supplier of the Harvey Smith trick up-pipes, please be aware of (often more expensive) poor performing copies.........
Postby asperformance » Tue Aug 25, 2015 3:11 pm
slightly revised pricing
Postby asperformance » Thu Jan 21, 2016 9:45 am
have had some slight cost increases and a v.slight re-design to accomodate which has meant the prices have had to be adjusted
std 2bolt fitment "trick" up-pipes are £165.00inc./fully DEI heat wrapped and with 5x new studs and delivered to std UK postcodes
2 bolt and 3 bolt "GT Spec, RCM, Lateral, etc." type fitments also available at £172.50inc./fully DEI heat wrapped and with 5x new studs and delivered to std UK postcodes
we also carry stock of the GT2 Spec / RCM header kits at very competitive pricing if required
just contact the office direct by phone or email to sort specific details / order
Return to AS Performance
