Engineering Serviceswith our extensive range of contacts we are able to offer various bespoke engineering soloutions - wether its adapting an existing brake kit, installing "coopers rings" into heads, re-manufacturing obsolete gear parts or supplying 'one-off' components we can usually fulfill the brief given
please contact with your requirements a couple of recent projects.............whilst these are all Subaru orientated we cater for any owner/vehicle light weight brake kit to suit 15" wheels for drag specific use std single scroll "clubman" baffled sump pan twin scroll fully baffled sump pan ASPerformance
slightly different project a "grpN" style servo eliminator kit..........this is fitted to an evo6 but also do the various Impreza ones required including the new hatch STi, allows full anti-lag use without compromising brake pedal feel
latest project - Skyline R35 GTR brakes adapted to fit R33.......
and 14mm head stud conversion..........
lots going on but a few things of interest..........
Impreza 5 & 6 speed gear linkage bush kits to improve the std shift quality/feel Impreza master cylinder stopper/support ASPerformance
we already offer a block "pinning" service but we have recently been spending time further developing the bracing/strengthening of the open and semi-closed deck blocks in particular for the 2.5 engine, the latest spec has seen an insert produced to fully "close" the top cylinder deck
like all "high power" builds/basis it will be as reliable as anything else with the correct supporting mods
its designed to allow the 2.5 to be modded above the current accepted "safe level" of around 500........... already have "pinned" EJ25 blocks running at high 500's and this is a far more comprehensive soloution ASPerformance
and a new addition sees possibly the "first" CDB inserted 6 cylinder EJ33 block....................
also we have machined "blanks" to be fitted into the block bolt access holes to fully enclose on final assembly (not pictured) Last edited by asperformance on Mon Feb 20, 2012 7:55 pm, edited 1 time in total.
and a nice little trinket to go along with the more major work.............
sneak peak of the latest development, better pics to follow once i sort the camera..............
still a work in progress ASPerformance
and a more finalised pic............insert fully machined and early EJ25 open deck block modified for 14mm stud conversion / rear thrust crank
a lot of the newer AP Racing kits include a disc set-up to AP's own semi-floating design, however they will only supply complete units of discs/bells on-going so can be quite expensive to keep on top of................
this is actually an Evo X set-up but is a conversion to use a more widely available 355mm disc and our own bells ASPerformance
something a little different..........
we were asked to look at a Vauxhall aluminium block for a high power turbo application and see if we could carry out the same "closed deck insert" work to this application, semi-finished reults............. ASPerformance
custom brake kit for Peugeot 106 Rally car utilizing AP Racing cp5040 brake calipers and PFC 295mm brake discs
EJ257 complete with closed insert and flanged liners machined & fitted..........
Re: Engineering ServicesASPerformance
Re: Engineering Serviceswe are in the process of finalising our own uprated studs to specifically suit the H6 cars using turbo's...................
also now finalised a CDB insert to suit the EZ30 Legacy engine ASPerformance
Re: Engineering Servicesplaying with the "other side" - wide range of engines and marques catered for on a daily basis
Ford RS / Volvo T5 CDB inserted block Honda K20A CDB inserted block ASPerformance
Re: Engineering Servicesanother little job we have done for some time but always forget to post pix..........
ASP custom modified high castor suspension arms ASPerformance
Who is onlineUsers browsing this forum: No registered users and 33 guests |
