Rev Limiter
Postby jrf567 » Tue Nov 09, 2010 9:56 pm
Just got a WR1 and am trying to find out how the Rev Limiter works. Have had a fiddle but still not convinced I got it right.
Any views or signposts for me?
jrf567
Postby MaverickUK82 » Tue Nov 09, 2010 11:11 pm
Turn it off ;-)
If I remember correctly, you have the key in the ignition, but not have the enginer running, then you can twiddle the nob below the rev counter to adjust it to where you want it set, press the nob, then you have an option to make it beep when you hit that setting or just have the light on...
Postby WR 1mposter » Wed Nov 10, 2010 12:05 am
RTFM .....
oops forgot you aint got one
you guessed it !!!!!
£29,995 with free WR1 :lol: :lol: :lol:
Postby The Swede » Wed Nov 10, 2010 1:50 am
Some STi's didn't have too much of a rev limiter. Mine sure didn't (with a few burned out sensors as result :? ).
If you meant the little bird that tells you when to change gear though... Read the manual! :wink:
Re: Rev Limiter
Postby John Mc » Wed Nov 10, 2010 7:58 am
jrf567 wrote:Just got a WR1 and am trying to find out how the Rev Limiter works. Have had a fiddle but still not convinced I got it right.
From memory... with second ignition on.... I think you have to either push and hold or twist one of the "black sticks" below the rev counter and hold it there for a few seconds and then it goes into the adjustment mode. You can then alter the beep on/off and also the revs at which is comes on i.e. 63=6300 rpm etc
Re: Rev Limiter
Postby Megaman » Wed Nov 10, 2010 1:39 pm
:notwor:
Re: Rev Limiter
Postby buffy » Wed Nov 10, 2010 7:11 pm
how do you get the bleep turn on or off???
LBUFFIN
buffy
Postby MaverickUK82 » Wed Nov 10, 2010 8:25 pm
once you've pressed the button in to select the revs, you can then twist it again to either 'on' or 'off' (or similar, not sure if it actually says on an off...)
Postby buffy » Wed Nov 10, 2010 9:46 pm
but if you twist it the counter only goes up or down??
LBUFFIN
buffy
Postby dynamix » Thu Nov 11, 2010 7:36 am
This does not alter the rev limiter - only the gear change indicator light/beeper.
Rev limit is 7600 rpm.
Changing at 6300 means you are missing out on peak power - I would be taking to above 7k for sure.
Duncan : www.racedynamix.com
email: duncan@racedynamix.com
tel: 07540 185754
dynamix
Postby John Mc » Thu Nov 11, 2010 7:56 am
dynamix wrote:This does not alter the rev limiter - only the gear change indicator light/beeper.
Doesn't the peak power depend on the power curve for your particular car? Mine, according to the rolling road graph (for whatever reason) was at 6300...
Postby CAVEMAN » Thu Nov 11, 2010 8:04 am
just use your own ass dyno and see at what revs you start to drop off at....then set the light/beep accordingly.
Postby dynamix » Thu Nov 11, 2010 8:42 am
Unusually low that for a 2.0 - did the graph dip just after that then slightly recover?
tel: 07540 185754
dynamix
Postby John Mc » Thu Nov 11, 2010 6:02 pm
It just tailed off slowly.
Postby MaverickUK82 » Thu Nov 11, 2010 9:21 pm
Peak bhp for WR1 was supposed to be at 5800rpm, or so it stated in the book.
Postby MaverickUK82 » Thu Nov 11, 2010 9:23 pm
I did make a MSExcel spreadsheet thing once that you could feed your figures from a dyno in to, and it worked out where each gear change would leave you in the rev range and therefore you could find out where is the best place to change gear... I could find it on old comp' and post it if anyones interested.
I turned out for my wr1 the ideal gear change was at 7600 as you'd expect.
Postby The Swede » Thu Nov 11, 2010 9:49 pm
Agree with the above. I always changed at 7500 or higher. Just keep it nailed. As long as there is no pistin shooting out of the wheelarche, you're OK.
Postby MaverickUK82 » Fri Nov 12, 2010 11:46 am
I had once owned a '93 RS2000 escort (first car) that I found out (after buying it) had had a full engine rebuild due to the 'cam shooting through the bonnet'...
...still love that car.
Postby Megaman » Fri Nov 12, 2010 3:40 pm
The Swede wrote:Agree with the above. I always changed at 7500 or higher. Just keep it nailed. As long as there is no pistin shooting out of the wheelarche, you're OK.
:lol: :lol: :lol:
Return to AS Performance
