Rev Limiter
PostPosted: Tue Nov 09, 2010 9:56 pm
by jrf567
Just got a WR1 and am trying to find out how the Rev Limiter works. Have had a fiddle but still not convinced I got it right.
Any views or signposts for me?
PostPosted: Tue Nov 09, 2010 11:11 pm
by MaverickUK82
Turn it off ;-)
If I remember correctly, you have the key in the ignition, but not have the enginer running, then you can twiddle the nob below the rev counter to adjust it to where you want it set, press the nob, then you have an option to make it beep when you hit that setting or just have the light on...
PostPosted: Wed Nov 10, 2010 12:05 am
by WR 1mposter
RTFM .....
oops forgot you aint got one
you guessed it !!!!!
£29,995 with free WR1 :lol: :lol: :lol:
PostPosted: Wed Nov 10, 2010 1:50 am
by The Swede
Some STi's didn't have too much of a rev limiter. Mine sure didn't (with a few burned out sensors as result :? ).
If you meant the little bird that tells you when to change gear though... Read the manual! :wink:
Re: Rev Limiter
PostPosted: Wed Nov 10, 2010 7:58 am
by John Mc
jrf567 wrote:Just got a WR1 and am trying to find out how the Rev Limiter works. Have had a fiddle but still not convinced I got it right.
From memory... with second ignition on.... I think you have to either push and hold or twist one of the "black sticks" below the rev counter and hold it there for a few seconds and then it goes into the adjustment mode. You can then alter the beep on/off and also the revs at which is comes on i.e. 63=6300 rpm etc
Re: Rev Limiter
PostPosted: Wed Nov 10, 2010 1:39 pm
by Megaman
:notwor:
Re: Rev Limiter
PostPosted: Wed Nov 10, 2010 7:11 pm
by buffy
how do you get the bleep turn on or off???
PostPosted: Wed Nov 10, 2010 8:25 pm
by MaverickUK82
once you've pressed the button in to select the revs, you can then twist it again to either 'on' or 'off' (or similar, not sure if it actually says on an off...)
PostPosted: Wed Nov 10, 2010 9:46 pm
by buffy
but if you twist it the counter only goes up or down??
PostPosted: Thu Nov 11, 2010 7:36 am
by dynamix
This does not alter the rev limiter - only the gear change indicator light/beeper.
Rev limit is 7600 rpm.
Changing at 6300 means you are missing out on peak power - I would be taking to above 7k for sure.
PostPosted: Thu Nov 11, 2010 7:56 am
by John Mc
dynamix wrote:This does not alter the rev limiter - only the gear change indicator light/beeper.
Doesn't the peak power depend on the power curve for your particular car? Mine, according to the rolling road graph (for whatever reason) was at 6300...
PostPosted: Thu Nov 11, 2010 8:04 am
by CAVEMAN
just use your own ass dyno and see at what revs you start to drop off at....then set the light/beep accordingly.
PostPosted: Thu Nov 11, 2010 8:42 am
by dynamix
Unusually low that for a 2.0 - did the graph dip just after that then slightly recover?
PostPosted: Thu Nov 11, 2010 6:02 pm
by John Mc
It just tailed off slowly.
PostPosted: Thu Nov 11, 2010 9:21 pm
by MaverickUK82
Peak bhp for WR1 was supposed to be at 5800rpm, or so it stated in the book.
PostPosted: Thu Nov 11, 2010 9:23 pm
by MaverickUK82
I did make a MSExcel spreadsheet thing once that you could feed your figures from a dyno in to, and it worked out where each gear change would leave you in the rev range and therefore you could find out where is the best place to change gear... I could find it on old comp' and post it if anyones interested.
I turned out for my wr1 the ideal gear change was at 7600 as you'd expect.
PostPosted: Thu Nov 11, 2010 9:49 pm
by The Swede
Agree with the above. I always changed at 7500 or higher. Just keep it nailed. As long as there is no pistin shooting out of the wheelarche, you're OK.
PostPosted: Fri Nov 12, 2010 11:46 am
by MaverickUK82
I had once owned a '93 RS2000 escort (first car) that I found out (after buying it) had had a full engine rebuild due to the 'cam shooting through the bonnet'...
...still love that car.
PostPosted: Fri Nov 12, 2010 3:40 pm
by Megaman
The Swede wrote:Agree with the above. I always changed at 7500 or higher. Just keep it nailed. As long as there is no pistin shooting out of the wheelarche, you're OK.
:lol: :lol: :lol:
