http://www.maxspeedingrods.co.uk/high-p ... e-red.html
Fit for : For BMW 3 Series (E36)
(Notice: Do not fit M3 convertible model)
Model years
-1991–1998 Europe
-1992—1999 US & Canada
Models
318i, 318is, 318ic, 323i, 323ic, 323is, 325i, 325is, 325ic, 328i, 328is, 328ic, M3, NOT FOR 318ti.
Quantity
2 piece front + 2 pieces rear
Spring rate Front
8 kg/mm (448 lbs/in)
Spring rate Rear
Adjustable damper: 24 ways adjustable
Adjustable height:Yes
Adjustable camber plate:Yes
Warranty: 1 year warranty for any manufacturing defect
Feature
Adjustable ride height
Adjustable pre-load spring tension
24 levels of adjustable damper -- This allows you the ability to perfectly dial in your coilovers system. For a nice comfortable driving, set damping to full soft. For more spirited driving, set it to 16 clicks. For occasional track days, set it to full stiff.
Pillow ball top mount -- this design helps combat noise while tuning. It also improves the steering feel and response
Most components are made from 6063 aluminum with T6 for increased hardness -- the advantages include excellent strength, and aluminum helps keep the weight down.
Hign Tensile performance spring - Under 600,000 times continuously test, the spring distortion is less than 0.04%. Plus, the special surface treatment is to improve the durability and performance.
All inserts come with fitted rubber boots to protect the damper and keep clean.
Improve your handling performance without sacrifice comfortable ride.
A fast and affordable way to easily upgrade your car's appearance.
Easy installation with right tools.
Ideal for any track, drift and fast road and can also be used for daily driving.
