RCM Prepared Impreza Spec C
Posted: Sun Nov 14, 2010 5:10 pm
Subaru Impreza Spec C
I fancy a change of car so I’ve decided to part with my 2005 Impreza Spec C which I’ve owned for 3.5 years. The car was imported into the UK by Litchfield Imports in 2007 and I’m the first UK owner. The car has currently covered 15,500 miles. This is my second car and it’s always been garaged and only used on dry days.
The car has been built and prepared by Roger Clark Motorsport to the highest standard. This has been a money no object car and only the very best of components have been supplied and fitted.
The engine was only fitted 5000 miles ago and the brakes have only been on the car for 3000 miles. The car was serviced in September and since then has only covered 1000 miles.
The car comes with 10 months MOT and has 7 months left on the tax. At present there is a private number plate assigned to the car which is not part of the sale. The car has a CAT 1 Alarm & Immobiliser and is also fitted with a tracker and the tracker navigation system.
The Spec C has many improvements of the UK STI including the twinscroll turbo, up to 120kg lighter than a standard STI, with lightweight glass, roof, bonnet, boot lid, driver controlled centre diff with auto switch, front revised diff control unit with additional sensors, different radiator, water pump & additional engine & transmission oil coolers for improved cooling, rear strut brace, stronger front suspension strut towers & supports, 12 litre cooler water spray bottle behind the rear seats for better weight distribution with automatic mode as well as manual, roof vent, high revving 8000 redline, unique black Spec C interior, spec C badges, climate control, body coloured mirrors, electric mirrors, alloy pedals and electric front & rear windows.
Engine
EJ20 Engine built by Roger Clark Motorsport
Omega Pistons
ACL Race Main Bearings
ACL Race Big End Bearings
RCM Modified Oil Pump
14mm Head stud conversion
RCM Baffled Sump
RCM 800cc injectors
PFR7B Spark Plugs
Walbro Fuel Pump
SX Fuel Pressure Regulator
RCM Induction Kit
RCM Cool Panel Guide
Full RCM exhaust system including headers
Hyperflow Front Mounted Intercooler
AP Racing Clutch
RCM Flywheel
RCM Lightened Pully’s
Motec M800 ECU
Motec Cam timing software
Motec Lambda support
Motec Advanced Tuning Upgrade (Anti Lag & Launch Control)
Motec Lambda sensor
Motec Lambda Loom
Motec Lambda Adaptor
Motec Cable to ECU
Samco Hose Kit
RCM Bespoke Oil Catch Tank
Brakes
Front AP Racing 6 Pot brakes with goodridge hoses
Rear AP Racing 4 pot brakes with goodridge hoses
Handling
RCM 4 wheel Laser Alignment
Wheels & Tyres
Toyo R888’s 235/40/18
18â€
Engine
Omega Pistons
RCM Baffled Sump
RCM 800cc injectors
PFR7B Spark Plugs
Walbro Fuel Pump
RCM Induction Kit
AP Racing Clutch
RCM Flywheel
Motec M800 ECU
Motec Lambda sensor
Motec Lambda Loom
Motec Cable to ECU
Samco Hose Kit
Brakes
Handling
Wheels & Tyres
18â€
