WR1 left it's home in the UK to roam the German Autobahn...
Say Hi and tell us a little bit about yourself.
Postby MikeStyles » Sun Mar 15, 2015 7:36 am
Hi guys,
#292 has left the island and now is going to explore the Autobahn and Nürburgring region... :D
It'll be the new compagnion of my Lancia Delta HF Integrale Evo which is at the moment in a full rebuild and should be ready in summer.
Going to post some pics after the Scooby's TÜV & registration - will take some time and prep though.
Cheers to all for the help & advice
Micha
MikeStyles
Re: WR1 to roam the Autobahn
Postby WR1 » Sun Mar 15, 2015 7:51 am
Nice work - enjoy!
WR1
Postby MikeStyles » Sun Mar 15, 2015 4:53 pm
First trip today: :lol:
Cheers! :wink:
MikeStyles
Postby Scootwr9 » Sun Mar 15, 2015 8:25 pm
Like I said... a good home ! Lol
Scootwr9
Postby WR1 » Tue Mar 17, 2015 9:02 am
Nice - looks at home !!
WR1
Postby MikeStyles » Thu Mar 19, 2015 4:49 am
Deleted.
MikeStyles
Postby WR1 » Thu Mar 19, 2015 8:55 am
Way cool - how do you find the WR1 in comparison to the EVO?
WR1
Postby WR1 » Thu Mar 19, 2015 9:12 am
If you are close to the Ring you should join up with this lot - I'm toying with the idea of going:
http://www.southeastscoobies.co.uk/vbul ... hp?t=19465
WR1
Postby MikeStyles » Thu Mar 19, 2015 10:29 am
Ian from SouthEastScoobies allready got in contact with me - we'll meet up at that weekend. :D
The Delta Evo is quite different - engine is more like the 2.5ltr Scoobies due to the long stroke and the supension / handling demands a lot more knowledge / experience (never brake or let off the gas pedal in a fast corner - it will spin you out). Steering feel is far better with the Deltas (very "Porsche GT3-like") and they understeer less under power if you've got an 16v Evo - and it feels a lot more compact too. Rattles and squieks all the time but that's character... :wink:
Cheers!
MikeStyles
Postby BIG"E" » Thu Mar 19, 2015 5:59 pm
WR1 wrote:If you are close to the Ring you should join up with this lot - I'm toying with the idea of going:
Do it !!!!!!!
BIG"E"
Postby asperformance » Thu Mar 19, 2015 6:13 pm
you must have bought Scott's car, nice to see its gone to a good home...........
not sure if he mentioned about the ECU but will try and drop you some info about some slight niggles
Postby MikeStyles » Thu Mar 19, 2015 8:36 pm
Yes I did - dropped you a PM. :D
MikeStyles
Re: WR1 to roam the Autobahn - finally passed German TÜV
Postby MikeStyles » Sat Apr 18, 2015 10:39 am
Hi guys,
passed german TÜV this week and now on new plates - you like ´em?
By the way - "AW" is the Nürburgring region / district - a rather nice combo... :D
Cheers guys!
Micha
MikeStyles
Re: WR1 to roam the Autobahn - finally passed german TÜV
Postby BIG"E" » Sat Apr 18, 2015 4:41 pm
Very nice,
It is a good job you dont live in the Cochem area.. :wink:
BIG"E"
Postby Scootwr9 » Mon Apr 20, 2015 6:57 am
Nice !!! Looking well !!
Scootwr9
Postby WR1 » Mon Apr 20, 2015 8:33 am
Way cool.
WR1
Postby ScrumpyJames » Mon Apr 20, 2015 10:12 am
superb!!!
ScrumpyJames
Postby MikeStyles » Tue Apr 21, 2015 6:11 am
@ Big E
You're right mate - the plate would start with "COC-..." - lol! :lol:
MikeStyles
Postby MikeStyles » Wed Apr 29, 2015 1:50 pm
Okay - end of May the WR1 get´s a prep for a remap - going to drive to the Netherlands:
http://ems-tuning.nl/
Rather famous in the western part of Germany - this will be a first "meet & greet" to evalute the Scooby and it´s setup.
Awaiting a quote and opinion whether the WR1 needs a final remap (as AS Performance suggested). :idea:
Keep you updated & C U soon at the Nürburgring
Micha
MikeStyles
Postby MikeStyles » Fri May 15, 2015 4:40 am
Hi Guys,
small update on the WR1 as we are prepping it to get it´s full potential out of it... :D
After installing a heat-shield for the turbo to protect the intercooler and changing the turbo hoses for a Samco kit I started
to build a new air deflector (the part that runs the air from the scoop into the intercooler.
As a big Perrin topmount is installed it looked like this with the factory seal:
If you look closely you can see the "scratches" of the factory seal on the surface of the IC so two rows on each side plus 3cm on top pf the IC weren´t in the airflow plus there was no sealing on the lower part at all.
After a whole day of measuring, cutting, fitting, measuring, cutting, fitting,... etc. :roll: it ended up like this:
Looks fairly strange and a little bit skew (as the IC has quite some angle regarding it's mounting points and is a bit "off" compared to the scoop) but it works rather nicely and seals perfect.
And don't mind the gaffer tape - it covers the various holes from the factory seal plugs. :wink:
We also reprogrammed the APEXI and next week it´s off to get a remap.
Keep you updated
Micha :)
MikeStyles
Postby WR1 » Fri May 15, 2015 8:47 am
Nice work bud!
WR1
Re: WR1 left it's home to roam the German Autobahn...
Postby MikeStyles » Tue May 19, 2015 7:08 pm
Hi Guys,
got the WR1 checked and remapped by the well known Subaru workshop EMS Tuning in the Netherlands - as always they detected a faulty Neutral Switch so the Intake Cam Actuator did not work...
Sorted that out and after the mapping plus APEXI "wizardry" :D it made 450bhp at 6800rpm plus 480NM at 5500rpm.
The big turbo flaws the spool-up and the total amount of torque (the real power starts at 4500rpm) but it races towards the redline and the torque stays nearly level up until 7500rpm.
Micha
MikeStyles
Postby WR1 » Tue May 19, 2015 9:24 pm
Wow big figures - is that on standard internals?
WR1
Postby MikeStyles » Wed May 20, 2015 3:28 am
@WR1
Can't say really as the car has been soooo many times at different tuners in the UK since 2013 - the ECU itself has been remapped 98 times (the info can be found in the ECU) !!! :shock:
But when it left the island it already made 418bhp and the APEXI wasn't really used in a proper way, the IC airduct was crappy and the IC hoses were junk...
Micha
MikeStyles
Re: WR1 left it's home in the UK to roam the German Autobahn
Postby asperformance » Fri May 22, 2015 7:41 am
good to see its more sorted
not sure why it had been set-up in that format possibly simply limited knowledge??
IMO would have been far better with a 3port installed and mapped to move the boost control back onto the ECU - but we had limited time and at the owners request the car was made "safe" as opposed to its previous state
Return to New-comers say Hi
Users browsing this forum: No registered users and 51 guests
