Hi guys, this was a guide done for the scoobynet people and thought i'd post it in here too
How to safely and effectively correct Subaru paint by hand
If you choose to work by hand on Subaru paint you've got little chance of removing all of the defects present, so often the best bet is to use a glaze like Menzerna Finishing Touch Glaze or Blackfire Gloss Enhancing Polish to fill and hide the defects and then seal the finish with a decent wax or sealant (to boost the gloss and lock in the fillers). This approach is straightforward and relatively easy in terms of product application and removal. However, if you are happy to put in a lot of hard work, then it is possible to achieve a reasonable degree of correction by hand, providing you use a polish with a high degree of cut but that also breaks down effectively with just hand pressure. Few polishes have these characteristics, but one that does and that we highly recommend is Menzerna Intensive Polish. Here is an example of what can be achieved with it...
Before
All of the usual suspects can be seen here; marring, swirl marks and deeper random scratches. Once again note that swirl marks are not circular patterns. Instead, they are simply the result of a lighting source reflecting off of the edges of widespread multi-directional random fine scratches...
Step 1
There are many different types of polish available on the market today, but one of the few that is capable of producing excellent results when working by hand on harder paints is Menzerna Intensive Polish. I recommend applying it using the white side of a German Pad, and buffing off the spent residue with a Poorboys Super Thick & Plush Towel...
Step 2
This is how much polish I recommend using per 12â€
