John's RB320 Correction Detail...
Postby Clark » Mon Apr 04, 2011 10:19 pm
Copied over from DW:
This particular RB is the Original Press car and is actually the exact one that EVO Magazine reviewed and drove rather swiftly in this video below:
http://www.youtube.com/watch?v=GoPDWBvRWwY
So understandably the paint was looking rather sorry for itself as Motoring Journalists aren't really know for their passion of car care!
In the shade the car looks pretty good on arrival:
However, if we go to the other side we can see all sorts of defects lurking:
The owner was going offshore so the car was left with us for 2 weeks which meant I could work on it in between other jobs and not have to worry about finishing to a strict deadline.
First up I decided to remove the wheels as I could see there was alot of old weight stickers and residue which were going to be a pain to remove if the wheels were still on the car:
The process was as follows:
Sprayed with R222 wheel gel
Agitated with a Swissvax Wheel Brush...
...and Wheel Woolie.
A rinse followed before Autosmart Tardis was applied to remove some tar spots:
This was rinsed off and Wolfs Brake Duster was applied and agitated after a few minutes:
A combination of Tardis and the Heat Gun was used to remove the old residue:
Swissvax Cleaner Fluid and then Autobahn were applied to each wheel and buffed off:
The arches were cleaned with Meguiars Super Degreaser while each wheel was off but I never took pictures as they weren't too bad to begin with in all honesty.
With all 4 wheels cleaned, protected and back on the car it was time to crack on with all the other details:
Foamed first at a temperature of approx 60/65 degrees:
Thoroughly rinsed at the same temperature:
Engine bay sprayed with Meguiars Super Degreaser and a Swissvax Brush:
Followed by a rinse at medium pressure:
The car was then left to idle for 5 minutes.
Boot, door shuts, exterior trim etc cleaned with Meguiars APC:
The car was then washed with the 2 bucket method, lambswool mitt and Meguiars Shampoo Plus before Autosmart Tardis was applied to all paintwork and glass:
This was rinsed off after being wiped over with an old MF towel.
Wolfs Brake Duster was then applied and wiped over with a MF towel the same as Tardis before a final rinse off.
Now inside, I clayed with an Autosmart Clay I'd been given to test and water as lube:
Despite the chemical cleaning during the wash stage there was still a considerable amount of contamination coming off the paintwork, this is after half the roof:
Once fully clayed I dried the car off with a PB Luxury Drying Towel and the Black Baron.
Now clean and free of any products that may have been filling any defects the true condition of the paint could be seen:
A couple of bits were removed to make polishing easier such as the side repeaters and washer jets:
I then took detailed paint readings which showed the car had a consistent level of paint, unfortunately it was consistently thin! On average it was between 75-85 microns with a couple of high spots just touching 3 figures.
Fortunately, despite the severity of the defects present in the paintwork I was confident I could achieve excellent results with minimal paint removal as experience has shown Subaru’s of this age are incredibly soft and sticky (my own car being true to form!).
So with that in mind, I tried a very mild polish and pad combination - 3M Ultrafina and a 3M Polishing Pad. The paint was extremely sticky but the oily nature of UF and slowly building the RPM's of the rotary helped keep panels temperatures to a minimum.
Here’s the result after my test section with a total paint removal of 2 microns:
Many people would have went for a stronger combination when looking at the defects but it just goes to show what can be done with the right pad and polish!
A couple of panels in I swapped to green Lake Country Polishing Pads as the 3M pad was starting to grab a bit when loaded with polish and the LC one ran a bit cooler while still cutting well.
Some more correction shots, in no particular order:
A-Pillar before:
After:
Rear quarter before:
After:
Window spoiler before:
After:
Lights before:
After:
Boot lid before:
After:
Before:
After:
N/S door before:
After:
I think this 50/50 should show just how much clarity the defects were robbing the paint!...
Fortunately I got a break from the sticky paint when it came to polishing the plastics. These were slightly harder and thicker than the metal panels so Wolfs WP-5N with a Tangerine LC HT pad were used for these:
Before:
After:
Before
After:
Rear bumper before:
50/50:
After:
Number plate recess before:
After:
Side skirt before:
After:
The headlights were slightly weathered:
After:
Front bumper wasn't too bad for defects as it had been painted at some point, although there were quite a few bug etchings:
After:
Before:
After:
Along with the front bumper, the bonnet and wings had been re-sprayed too but were the complete opposite to the original paint, they were pretty hard and at an average of 190 microns fairly thick.
For these panels I used a Cyan Lake Country HT Pad with Wolfs WP-6H to achieve the following results:
After IPA:
In between all the polishing I'd called Martin from Dent Devils in to take care of a few dings on the N/S door:
Martin at work:
And literally 2 minutes later - all gone!
With all the correction work done I put the car outside to give it a thorough rinse down. Ultrafina wouldn't usually dust much but when you're dealing with sticky paint you're dealing with dust like it or not! :D
Looking much better already:
After drying with the Black Baron I refined the paint with Ultrafina again but this time with the DA and some LC HT Finishing Pads:
This was a time consuming step which took a whole Saturday to do as I had to make sure the polish was completely broken down and then avoid marring the super soft paint when buffing the polish off (which tends to want to weld itself onto the paint on sticky panels!)
Eventually I got there (after re-doing a couple of panels as a result of inflicting some light marring) though so after a light dust down and IPA wipe down I applied Blackfire All Finish Paint Protection:
This was left for 20 minutes until I could leave a clean swipe with my finger:
Buffing off with a Poorboys DMT:
I then completed the rest of the car which included the interior glass with Swissvax Crystal (love this stuff!)
Vents etc dusted out before thoroughly hoovering and then wiping down all surfaces with APC:
Matts cleaned and protected:
Postby Clark » Mon Apr 04, 2011 10:20 pm
A final wipe down of the paint with Blackfire Deep Gloss Spray was done before I re-fitted the washer jets and side repeaters:
And that's pretty much it, I suppose I better show you the after pics, remember 95% of this result was achieved with a very mild polish and pad combination :thumb:
And with the plates back on, ready for some more sideways fun :driver:
Thanks for reading (or even just scrolling through the silly amounts of pics :p)
Postby Bonovox » Mon Apr 04, 2011 10:37 pm
Oh my god, I love seeing these but always end up feeling like my cars pish :cry:
Bonovox
Postby SteveS » Mon Apr 04, 2011 10:42 pm
Absolutley stonking Clark, what a result, I have studied your detailing on the WR1 and it looks stunning, great pics. very well done. :D
SteveS
Postby Cozzy 481 » Mon Apr 04, 2011 10:48 pm
Incredible work Clark, The paint was in terrible condition to start with. Always amazed at the end results,you sure you aint got a spray booth out back! :lol:
Bmw 320ci msport
Bmw 323i tour msport
wr1 481 (New)
Shogun (06) SORRY
Bmw 330i m sport
Bought WR1 481 back.(SOLD)
Subaru Tribeca B9 SE7 2007.
Cozzy 481
Postby WR 1mposter » Tue Apr 05, 2011 12:20 am
Top work again Clark. 8)
Postby Megaman » Tue Apr 05, 2011 11:40 am
Great work Clark although I think you could of taken a few more pics :lol:
Will have to change your signature to "Clark, hitting your broadband download limit in one thread" :lol:
Good job anyway :)
Postby Clark » Tue Apr 05, 2011 12:03 pm
I'd rather have "Picture Whore" :lol:
Postby WR1 Bro » Tue Apr 05, 2011 12:26 pm
More pics the better for me. Love it.
Postby Scooby Si » Tue Apr 05, 2011 12:40 pm
Awesome result and really good write up Clark
Scooby Si
Postby John Mc » Tue Apr 05, 2011 3:41 pm
Pictures > words!
Fookin awesome Clark as per usual :lol:
Postby Chris 280 » Tue Apr 05, 2011 8:29 pm
awsome job mate,must have aded a few quid to the value :)
Chris 280
Postby Megaman » Tue Apr 05, 2011 8:47 pm
Im still waiting for Clark to take on my mucky WR1 challenge, would need its own forum for the pics with the amount of work it would take to thoroughly clean mine :lol:
Do you respray parts of a car or fill in chips/pain them or refurb alloys as part of any of your services Clark?
Postby stanley » Wed Apr 06, 2011 10:10 pm
Nice work Clark..can you tell me when you say "could not remove any more paint to get 100%" are you cutting the clearcoat..or the paint?
Regards Stanley
________
Live sex webshows
stanley
Postby zedder » Thu Apr 07, 2011 9:05 pm
looks amazing !! 8)
zedder
Postby Lee190888 » Thu Apr 28, 2011 6:07 pm
Absolute Genius! How much did this work cost Clarke?
424
Lee190888
Postby Ferret WR1 » Thu Apr 28, 2011 7:17 pm
Stunning! :D
Ferret WR1
