Number plate screws...
PostPosted: Tue Jul 27, 2010 11:55 am
by MaverickUK82
I obtained an unsightly crack in my front number plate, obviously from a stone or something.
Anyways, I bought a new one and decided to fit it.
The original plate was fitted with white two plasticy\rubbery screws. Of course they both snapped when removing the plate leaving the buggers stuck in the slots...
Anyone know what these screws are or how I can get them out?
I've had to stick the new one on, although, the sticky pads are really thick and makes the plate stick out as if it's attached to the end of a broomstick (maybe that's a bit of an exaggeration, but annoying none-the-less).
PostPosted: Tue Jul 27, 2010 4:52 pm
by John Mc
Drill them out using a progressively larger drill size each time... start with 0.5mm and work larger until you can get something inside the hole and unscrew from the middle (if possible)if you go too large with the drill bit, you'll have to re-thread the hole worst case. Just take your time.
PostPosted: Tue Jul 27, 2010 5:13 pm
by WR 1mposter
prefer them stuck on !
PostPosted: Tue Jul 27, 2010 5:44 pm
by John Mc
WR 1mpostor (aka number 1 moderator) wrote:prefer them strap on !
:shock:
PostPosted: Sun Apr 03, 2011 1:21 pm
by mikethatcher
Whats the best stuff to use to stick the plates on ? iam going to renew mine soon. Thats if i can get the old one off :x
PostPosted: Sun Apr 03, 2011 2:13 pm
by huzzy
Double sided green stuff from Halfords. It's good!
PostPosted: Sun Apr 03, 2011 2:30 pm
by WR 1mposter
mikethatcher wrote:Whats the best stuff to use to stick the plates on ? iam going to renew mine soon. Thats if i can get the old one off :x
Go to halfrauds by all means, but probably pays loads more plus the time an fuel :lol:
or ebay !
http://motors-parts.shop.ebay.co.uk/Veh ... 86.c0.m282
PostPosted: Mon Apr 04, 2011 9:18 am
by MaverickUK82
I stuck mine on in the end. been on ages now.
just make sure the plate and car are clean before sticking them on!
PostPosted: Mon Apr 04, 2011 7:13 pm
by mikethatcher
Ideal, looks much better stuck on than drilled i think.
