John Mc Tiddler (Dogging Expert) wrote:Hi there,
Wanted to ask what you have had done to your WR1 to get over 400bhp!! Can you recommend any decent tuners?
What do you notice about the extra power over a standard WR1? I notice that (probably due to the large turbo) there isn't much below 2000rpm and when you pull out of a junction there's nothing...nothing... then all hell breaks loose!!
Mid range is great, love getting stuck behind people at the moment...
If your on about me pretty much everything that can be change via bolt on bits, turbo, turbo inlet duct, exhaust, fmic, injectors, caik headers up-pipe. I've used WRC Tech but they are long gone. Now use DSautos in Aylesbury they've been ok with me, plus they are the main dealer for APS product and pretty much everyhing on ours is APS
I've not really noticed the diffrence due to upgrading the turbo over the standard one down in the lower revs, after about 2500rpm you really notice the diffrence, you find its best to keep it singing rather than let it "bog down"......now there's a quote from years gone by !
As for pulling out on junctions you wait until safe to do so
smiles per miles is all I can say
