Scooby Lee..
Discuss other makes of cars here
Scooby Lee..
Postby SPIKE LIKE MIKE » Thu Jul 05, 2007 8:58 pm
Can you re-email me my 380 map please :lol: Ive wiped it off...pmsl
Due a service in a few weeks so need to flash it back on :D
How you getting on with the Ecuflash?
"Special Needs" constable
Postby The Swede » Mon Jul 09, 2007 9:46 pm
Do you want mine ?
Re: Scooby Lee..
Postby Scooby Lee » Mon Jul 09, 2007 10:55 pm
Spike "THE LEGEND" Mike XXX wrote:Can you re-email me my 380 map please :lol: Ive wiped it off...pmsl
Spike,
I've checked my collection of Maps and all the e-mails you've sent me, but I only seem to have your Anti-Lag Version.
I don't think you ever sent me the 'Original' 380!
Oh Dear... :roll:
Lee.
Sold out and bought an EVO......then sold it because it was rubbish!
Scooby Lee
Postby danr55 » Tue Jul 10, 2007 8:09 am
this all had to go wrong at some point! PMSL
Postby POESY » Tue Jul 10, 2007 8:40 am
Doh !!!
Send you the map for my car if you like spikey :wink:
POESY
Postby The Swede » Tue Jul 10, 2007 10:12 am
Spike, I sent you my original map. Should work as I assume they reflashed mine onto yours and Dan's. (plus it will ignore all the sh1te your MAF is sending as info to the engine :rofl:)
Postby Scooby Lee » Tue Jul 10, 2007 4:41 pm
Torrekens wrote:Spike, I sent you my original map. Should work as I assume they reflashed mine onto yours and Dan's. (plus it will ignore all the sh1te your MAF is sending as info to the engine :rofl:)
Spike,
Remember to change the Immobiliser Code if you use this map!
...otherwise the car won't start :shock:
Lee.
P.S. Can I have a copy of this map for my collection?
Scooby Lee
Postby SPIKE LIKE MIKE » Tue Jul 10, 2007 5:56 pm
Top men,
Gone another route altogether :D
Getting car serviced at SHM for
Postby Scooby Lee » Tue Jul 10, 2007 6:19 pm
...I'd still like a copy of the '380' Map!
Scooby Lee
Postby SPIKE LIKE MIKE » Tue Jul 10, 2007 6:29 pm
Scooby Lee wrote:...I'd still like a copy of the '380' Map!
Ill send sandys over to ya mate
Postby Scooby Lee » Tue Jul 10, 2007 7:11 pm
Good Man! :thumb:
Scooby Lee
Postby SPIKE LIKE MIKE » Tue Jul 10, 2007 7:19 pm
Good Man! :thumb:
How do you convert them back?
Postby SPIKE LIKE MIKE » Tue Jul 10, 2007 7:20 pm
and are sandys and my map "the same"?
Postby Scooby Lee » Tue Jul 10, 2007 7:40 pm
I can't read your map 'cos the one you sent was only 10kb......the Evo IX has a 512kb ROM file!
My first impression is that the '380' Map isn't brilliant; it's basically a Standard JDM GSR Map with a boost increase and a reduced stationary rev. limit.
It needs further study to produce a full evaluation......
Scooby Lee
Postby SPIKE LIKE MIKE » Tue Jul 10, 2007 7:41 pm
Original map sent in original format mate, :D
Postby Scooby Lee » Tue Jul 10, 2007 7:43 pm
......they've also slightly 'leaned-off' the higher load areas of the high octane fuel map, but it looks like they couldn't be bothered to amend the low octane one......which is a bit lazy!
Scooby Lee
Postby SPIKE LIKE MIKE » Tue Jul 10, 2007 7:45 pm
Scooby Lee wrote:......they've also slightly 'leaned-off' the higher load areas of the high octane fuel map, but it looks like they couldn't be bothered to amend the low octane one......which is a bit lazy!
NO SURPRISE though mate :wink:
Postby Scooby Lee » Tue Jul 10, 2007 8:02 pm
Spike "THE LEGEND" Mike XXX wrote:and are sandys and my map "the same"?
They appear to be identical (apart from the immobiliser code)!
Scooby Lee
Postby SPIKE LIKE MIKE » Tue Jul 10, 2007 8:05 pm
Exactly what I am now seeing...have turned the anti lag off quite easily...just edit teh RPM target from 2000 to 11000 therefore it effectively stops the injection/pulse of fuelling.
I also am changing the stationary RPM to 5500 and RPM limit to 6000 for servicing :lol:
Postby Scooby Lee » Tue Jul 10, 2007 8:16 pm
The 2000 RPM setting is for the operation of the secondary air system, it's not the only thing adjusted by Matt @ TRL to give you anti-lag......He's added a few sneaky adjustments (retardation) to the High Octane timing maps and (from the logs you've sent me) he's also offset the throttle position sensor scaling.
Basically, be careful! :shock:
Scooby Lee
Postby SPIKE LIKE MIKE » Tue Jul 10, 2007 8:18 pm
WTF is throttle sensor scaling? How much power for how much I press the loud pedal?
Postby SPIKE LIKE MIKE » Tue Jul 10, 2007 8:27 pm
Am I alsoright in thinking that anything I load need immobiliser code C201 and Sandy 2801?
WTF is an innit code?
Postby Scooby Lee » Tue Jul 10, 2007 8:29 pm
Spike "THE LEGEND" Mike XXX wrote:WTF is throttle sensor scaling? How much power for how much I press the loud pedal?
From the logs you sent me a few weeks (months) ago, it appears that your Throttle Position Sensor (TPS) doesn't return to zero when you 'back-off'......Instead, it seems to stop at 13% open.
Logs from my car show that the TPS has a full 0-100% Range.
Scooby Lee
Postby SPIKE LIKE MIKE » Tue Jul 10, 2007 8:32 pm
Whats that mean? Stays fuelling on lift off?
Postby Scooby Lee » Tue Jul 10, 2007 8:37 pm
Spike "THE LEGEND" Mike XXX wrote:Am I alsoright in thinking that anything I load need immobiliser code C201 and Sandy 2801?
You need your immobiliser code, which I assume is C201 (that's what's in both of 'your' maps).
The init code is the 'Initialisation Code' required to allow communication with your ECU. This is the number ECUTEK changes to 'lock' your ECU following a remap.
Scooby Lee
Postby Houdini » Wed Jul 11, 2007 12:56 am
Strewth! This all sounds very complicated. C201? Is that the next Citroen code name? There must be an easier car to own :shock: Is everything OK?
Houdini
Postby danr55 » Wed Jul 11, 2007 8:30 am
I'm lost! Spike, have you broken it?! :rofl:
Postby SPIKE LIKE MIKE » Wed Jul 11, 2007 6:19 pm
danr55 wrote:I'm lost! Spike, have you broken it?! :rofl:
Not yet...but Im trying VERY hard :bang:
Postby Houdini » Wed Jul 11, 2007 8:52 pm
This weekend should sort that out then :rofl:
Houdini
Return to Other Marques
